Old 12-07-2008, 10:36 PM
Default Powerglide problem !
Hopefully someone here has experienced the same problem as we have, and solved it.
The problem is that the powerglide won´t shift until after 15 to 20 minutes, when it is all warmed up. Once warm it shifts firmly and works just like it should. The transfluid has been changed since the car, a 1967 Impala, had been sitting for at least six years.
Any ideas ?
Anders Stålklint.
Old 12-07-2008, 10:52 PM
BARNFOUND YENKO BARNFOUND YENKO is offline
Default Re: Powerglide problem !
Do you have the proper vacume going to the trans? modulator?
SURVIVOR 1970 PLYMOUTH SUPERBIRD
ORIGINAL 1969 CAMARO Z/28
1968 CAMARO RS/SS L89 CONVERTIBLE-1 OF 1
Old 12-07-2008, 11:03 PM
Hoses and everything seems to be attached the way it should be. It´s hard to believe that it would work when it´s warm unless everything was connected the right way ?
Anders Stålklint.
Old 12-07-2008, 11:14 PM
It could possibly have something sticking in the valve body? filter change? Just ideas i am thinking of. It needs a good vacume source not a weak one.
