Old 12-06-2008, 01:59 AM
sssteve sssteve is offline
Default sound insulation
I'm restoring my 67 Caprice and this car is going to be a driver.I've done the roof and floorpans in "dynamat"in order to keep heat and mostly noise out of interior.Has anybody used an expanding foam product in the tight confines of the A and C pillars.There are plenty of products for the home but nobody can find any for automotive use or wheather the home ones are compatable.I'm sure I've seen a product in newer high end SUV's.Any suggestions out there?
1968 Camaro RS/SS 350 Conv.1967 Caprice 427 WARNING DO NOT TAKE THIS GUY SERIOUSLY OFTEN MEDICATED
Old 12-06-2008, 02:05 AM
Chevy454 Chevy454 is offline
Default Re: sound insulation
Be careful with that expanding foam...if you do use it, make sure you either "use semi-expanding" or "there's a way for it to relieve pressure"...we've used it in carpentry work and that foam can move stuff around if you're not careful! Lots of pressure when it starts doing it's thing...oh, and try and keep it off your hands!
Old 12-06-2008, 02:49 AM
I've used the home stuff many times and it comes in minimum,regular and maximum expansion types(I always used the minimum)but can it be used in an automotive application?Nobody can answer that question.
