Old 11-15-2008, 07:21 AM
cib12 cib12 is offline
Default 1967 RS conv 4 sp gauge pack &tach--one owner car
just purchased-leaving it good driver condtion-the top will go down with slight help-to raise it-more help is needed until it comes up close to the front-appears to have no leaky lines-did crack open a line(appears to have trans fluid in)-also lubed the pivots-how do you fill the motor if is low-fluid in the lines-but can see some air also- thanks
