Old 11-07-2008, 07:07 PM
Shankin Shankin is offline
Default M22 transmissions
Of all the m22s what is the strongest? I see some with 26 spline input shaft and some with 10. Also do they all have the same output shaft?
Old 11-07-2008, 11:06 PM
Default Re: M22 transmissions
Probably the 70 and later 26 spine input, and larger output spline models.
Paul
Old 11-08-2008, 12:28 AM
scuncio's Avatar
scuncio scuncio is offline
With a fine spline input/output you get a larger minor diameter, which should make them more resistant to twisting.
Old 11-09-2008, 02:52 AM
HPMIKE HPMIKE is offline
The gears and shafts on those were pretty stout, the cases, on the other hand, generally were not. I remember a time when all the Muncie and T-10's I did 50% had issues with case cracks.
MB
Old 11-09-2008, 05:29 AM
My tremec is not legal for the fast class so i am changing it for a m22. Just trying to figure out what one to use with around 500 to 550hp at the tires.
Old 11-09-2008, 07:20 AM
I would just use the Supercase and build from there. Or you could even find an iron T-10 case and build a pretty stout T10. The class allows use of different transmissions as long as they were made for a GM vehicle. One nice thing about the FAST class of racing is that the lack of traction definitely saves parts. Ed Cook's kid James grenaded the Hemi crash box I built for his RR, but that was attributed to driveshaft yoke failure. It's not likely that you would have any durability issues as long as you run the bias ply tire. Even less of a chance of trans failure with a "soft-lock" type clutdh that you would be wise to run.
Give me some details on the FAST build.
MB
Old 11-09-2008, 03:03 PM
I just sold my combination that was in my car so i could build my car up just for this class. It was making 557 rwhp and was a blast to drive but i never raced it. This will give me a chance to do something different , meet new people and see some awesome cars. With no more races than there are i will have plenty of testing time.
Combo will start with a nice BB with aluminum heads and a m22 proshifted.
Old 11-09-2008, 07:54 PM
I wonder if anyone makes straight cut gears for the muncie? The result would be a more effecient trans with more whine.
Paul
Old 11-09-2008, 09:10 PM
scuncio's Avatar
I wonder if AutoGear would make you a set of straight cut gears. If so, I am sure they'd be expensive.
I believe DNE (Doug Nash) made a pro-shifted gearset for the Muncie. I have seen DNE pro-shifted T10 gearsets. Not sure what helix angle was used in these but I gather it's a straighter angle like the M22, or possibly straighter yet. Keep in mind that straightening the helix angle will only increase the separating forces between the mainshaft and cluster gear, with a corresponding decrease in thrust (and probably a decrease in friction, but whether that's measurable is TBD). Ironically, many of the Muncie's problems stem from the separating forces between the mainshaft and cluster gear (case stretching), so are we really "fixing" anything by using the M22 helix angle? Just something to consider.
The Super Case, or the DNE cast-iron case, is probably the best bet for fixing the 'case stretch' issue.
(Note: I am not a transmission specialist and these are only my thoughts!)
Old 11-10-2008, 04:08 AM
So the super case is a must. I will be using an adjustable clutch so that should some what save the trans along with the tires.
