Old 11-02-2008, 09:28 PM
Z-11GUY Z-11GUY is offline
Default 1969 Caprice 396
Hello there,
I just brought home a 1969 Caprice coupe with all original 396 2 barell turbo 400 trans. The Caprice has the disc brakes and 12 bolt rear. The Car itself is tired and is rusty though the frame is super solid. It has all the dated exhaust manifolds, block heads etc. This would be a great car to use the frame,running gear and slide it under you 1965-69 Biscayne or Bel-Air 2-door sedan body (will bolt right up!). This would be the most economical way due to the disc brakes, big block springs and 12 Bolt already there. Also all the brackets, Big block radiator,PS pump is already there. No more scouring e-bay or the swap meets looking for everything!I plan to get it running this week, regards. $3,200.00
Default Re: 1969 Caprice 396
engine shot
Old 11-03-2008, 10:32 PM
JIM's Avatar
JIM JIM is offline
I could use some misc trim and interior parts if you have an interest in selling some small stuff off. Jim 302-420-4743
