Old 10-27-2008, 05:50 AM
Lostep Lostep is offline
Default I.D. on BBC
I have this BBC with this number on the front pad TI2I0IVR with F.F.79 beside it. The back pad reads 8855931 from what I can make out(still in car, not original to car). Can anyone tell me the year and what it came out of?
Hector
Old 10-27-2008, 06:01 AM
427.060 427.060 is offline
Default Re: I.D. on BBC
Check the casting number again. The IVR code is for a 1965-68 396/325hp with a Rochester carb.
1968 Beaumont SD396
Old 10-27-2008, 07:59 AM
SD 396 SD 396 is offline
Hi Hector
Like 427.060 said, check the casting number again. It's likely 3855961. Pad date Dec 10 1965 for 66 production full size or Chevelle. The F.F. 79 is likely a rebuilders stamp. Does it have a VIN stamped there? Also check the date casting on the block in front of the starter near the frost plug.
BTW. I got the SD finished I'll send you some pics.
Brad
Brad
1969 Beaumont SD-396 1 of 43
1968 Beaumont SD-396 1 of 680 (project)
