Old 10-27-2008, 03:03 AM
ss427copo's Avatar
ss427copo ss427copo is offline
Default Tach Issue has me puzzled. HELP!
Yo Gentlemen....
So, I take the instument cluster out of the 67 Impala Big Car to replace the clock. All goes relatively easy. It goes back together, the clock starts ticking like it should..BUT then the tach starts acting goofy. It worked perfect before. The sweep hand did get moved when it was out of the car (i used low, low pressure air to remove the 40 years of dust, but did not point the air at the tach's pointer) It went back in at about 200 RPM's, only moved to 2000 when I rev'ed it. Now it settles at 3000 like it should be at 0?? Any ideas?
Jeff
Jersey Jeff
69 Day-2 L89 T400 BX
2015 ZL-1 Auto
98 Surburban
Old 10-27-2008, 03:19 AM
napa68's Avatar
napa68 napa68 is offline
Default Re: Tach Issue has me puzzled. HELP!
Could it be that a ground for the tach or cluster was not reattached?
Tim
Old 10-27-2008, 03:41 AM
Alss's Avatar
Alss Alss is offline
I have a new tach that does the same thing..wont rev over 2000..was thinking grounds my self..still checking
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 10-27-2008, 04:31 AM
Jeff...definitely recheck the ground wire. It happened in my Chevelle as well...
