Old 10-26-2008, 06:42 AM
rpoz11's Avatar
rpoz11 rpoz11 is offline
Yenko Premier Member
Default 12 Bolt Axle ID ... Help
Was at a friend's shop earlier today.
He pulled out two(2) 12 Bolt axle housings.
One was coded BL 1220G1 ( no E below )
Dated K-8-7
The other was this:
C BS 0930G2
.........E <-----E being under the 9
Date coded I-26-9
Center casting number of 3969341 NF
What does he have???
Chavez Ravine
Old 10-26-2008, 07:55 AM
Kurt S Kurt S is offline
Default Re: 12 Bolt Axle ID ... Help
68 3.07 open
late 69 3.31 posi
http://www.camaros.org/drivetrain.shtml#RearAxleNumbers
Kurt S - CRG
Old 10-26-2008, 08:25 AM
rpoz11's Avatar
Thanx!
I was looking at that but you didnt have the C prefix codes listed.
I suppose I understand that one should just add the C prefix to the 2 Alpha codes to determine the 69-1/2 codes.
Did you get my emails???
Chavez Ravine
Old 10-27-2008, 09:36 AM
It shows up in the text:
Most of these later axles (10 or 12 bolt) would have also been stamped with the 1970 style three digit application code (e.g. CBT instead of just BT).
I thought it would have been confusing to add the extra codes in the table. But next time I edit that page, I'll try to make that part clearer.
Yes, got your email. Have been doing house projects....
Thanks!
Kurt S - CRG
