Old 10-04-2008, 05:40 AM
mockingbird812's Avatar
Default Frame Stampings
I looked for my frame stamp on the buildsheet and did not find it. Is it found on any other documentation?
Also, the date stamp "6 12 70" appears to be followed by a "2". Any insight?
Thanks!
Sam...
Old 10-04-2008, 07:00 PM
Hylton Hylton is offline
Default Re: Frame Stampings
What kind of car is this?
It is impossible to certify a COPO or Z/28 as authentic without verifying that it is not a rebody...
Old 10-04-2008, 07:45 PM
Rixls6 Rixls6 is offline
Sam,
If you clean a larger area around what you have pictured, I think you will find the buildsheet code to the left of what's seen.
Rick
Don't text and drive.
Old 10-04-2008, 09:00 PM
chads454Ls6 chads454Ls6 is offline
that is one clean frame. Wow!
Old 10-04-2008, 09:24 PM
Thanks Rick. I'll give it a try. Should I find the "XU-R" (box 11 of BS) stamped on the frame or would that only be noted via the sticker placed on the frame?
This is a 32,000 mile LS6 that spent most of its time in the south and did not see too much wx.
Sam...
Old 10-05-2008, 05:55 AM
firstgenaddict's Avatar
Maybe the 2 stand for 2nd shift? Or Line number etc?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 10-06-2008, 05:32 AM
Sam,
I looked at mine and found the XU stamped in without an R. It's buried behind an exhaust resonator, so I couldn't get a good look or pic, so there may be an R that I missed.
Rick
