Old 09-30-2008, 09:31 AM
Default Trans decode help
I got this off an M22 reads P1PO3C. Nbr on other side of case 9976171 and the metal tag nbr 978766 WO
I know it's a M22, but what else does it decode out as? Thanks, Schonye
Old 09-30-2008, 09:57 AM
Default Re: Trans decode help
P1P03C...
P = Muncie 4 speed, alum case
1 = 1971 model year
P = September assembly month (in this case, September 1970)
03 = day of assembly (9/3/1970)
C = M22
Is that 9976171 number cast or stamped? If it's a main case casting number, I have no idea what that's from, and it sure blows the P1P03C number out of the water.
Can't help you on the tag number.
Bill Pritchard
Old 09-30-2008, 06:43 PM
enio45 enio45 is offline
Crash - where are you?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-30-2008, 07:10 PM
The 9976171 is stamped. I felt that was the Vin nbr. The rest , as you decoded was what I thought, but wasn't sure.I didn't see a provision for a TCS plug in. Shouldn't there be on on a 71 trans?
Old 10-01-2008, 03:56 AM
That number is not consistent with any type of CON VIN from a 1971 model GM product. The CON VIN format should be N1Lnnnnnn, where
N = a number designating the GM division of the car (Chevrolet would be 1, and I believe Pontiac is 2)
1 stands for model year 1971
L = a letter designating the vehicle assembly plant
nnnnnn = the last six digits of the sequential VIN of the car
Colvin's book makes no mention of anything regarding the TCS switch provision
Old 10-01-2008, 08:40 AM
The M22 that I had in my deuce had a provision for a TCS plug in. I'll have to look again, but I don't remember seeing it on this one. I agree those numbers I gave really don't appear to be a sequential vin number, but it's the only other stamping in the main case.
A friend of mine is wanting to sell it, but he wanted to be able to tell a prospective buyer what it came out of. I'm not sure were going to find out.
Old 10-01-2008, 04:16 PM
crash crash is offline
If your going to look at it again??? Get all the casting numbers... And check the tag number, it should start with a 3 not a 9... Crash
Old 10-03-2008, 09:01 AM
Crash, it does have the TSC provision. I missed it the 1st time. The tag reads 978766 WO.Not sure the tag is original to the trans.
9352648 side cover
3978764 GM tail
3925661 case
PIPO3C STAMP
21200268 stamp on other side
Could be a case of mixed pieces.
