Old 09-25-2008, 03:45 AM
firez firez is offline
Default Open car trailer size
Is a 16 foot open trailer large enough to fit a first gen camaro on safely? Thanks for any feedback
1968 LOS Rallye Green Z28
Old 09-25-2008, 04:16 AM
x  Baldwin  Motion's Avatar
Default Re: Open car trailer size
The 67-69 camaro is 186" in over all length (15.5 feet) the trailers capacity (GLW) will determine the safety factor.
Old 09-25-2008, 04:38 AM
Thanks I will try a 16 and 18 foot model.
Old 09-25-2008, 05:05 AM
jeff morocco jeff morocco is offline
if you put your car on any open trailer, make sure the rear of your car does not stick out past the end of the trailer. a friend of mine put his camaro on a 16' trailer and was rear ended. the trailer had no damage at all but the camaro lost the bumper,gas tank,both quarters where the bumper caved in and the floor of the trunk from the tank was buckled. so be sure a 16 will work with your car in a safe towing position on the trailer. i'd go with an 18' to be safe.
Old 09-25-2008, 05:32 AM
Dog427435's Avatar
[b] Be sure to check the door clearance over the fender tops unless you always plan to winch it up!
Old 09-25-2008, 06:25 AM
Spring for the removable fiberglass fenders!
Howard
Old 09-25-2008, 06:19 PM
I would not do fiberglass fenders!!! In fact, I would stay away from removable fenders all together. A friend of mine had a tire go out on his open Featherlite. It had the removable drivers fender and when the tire blew, it knocked the fender off and into the car!!! That was an aluminium fender. I believe a fiberglass fender would have shattered and he would have had a tire 'gator' slapping the car!!! Some guys will use 2 or 3 2"x8" or 2"x10" boards stair-stepped so that the car will have enough clearance for the fender. Then there are the tilt back trailers and the roll back trailers that cause the fender to not be so much of an issue. Whatever you do, spend the money and get brakes on both axles and look at how the ramps are attached. If they just lay down and are not permanately attached, please take the time and drill some holes and put some pins in so that the ramp does not jump off while you are trying to load and unload the car.
Sorry about the rant, but I have seen too many issues with trailers and cars not getting along. I do not want your ride to be a victim.
1969 Hurst/Olds
13.26 @ 103.12 Pure Stock
Rusty Small
Old 09-25-2008, 06:40 PM
<font color="blue"> Here is a great trailer for your vehicle.
If you are coming to Fla. or anyone going back up ... </font>
trailer on yenko.net
Mike Fabian
Old 09-26-2008, 05:29 AM
J_D J_D is offline
Send a message via ICQ to J_D
I would agree with comments others have made. A 16' would work but an 18' would be better.
While I don't trailer a 1st gen Camaro, here are some pic's of my 4th gen on my 18' open trailer. You will notice how much room there is between the end of the car and the end of the trailer.
You will also want a trailer with a deflector on the front of it like mine has.
Both of my 4th gen Camaros have been lowered and the doors clear the fenders with room to spare.
J.D. Le Blanc
1997 30th Anniversary Camaro SS #742/2091
2001 Phase I Dale Earnhardt Intimidator SS Camaro #68
2002 Phase II Camaro ZL-1 Supercar #17
2010 Silverado LT 4X4 Crew Cab 6.2 liter
2011 Tahoe LS 4X4 Sport Utility 5.3 liter
Old 09-26-2008, 05:52 AM
67rscoupe 67rscoupe is offline
i would not like the idea of my car hanging off the back use a 18 footer.
