Old 09-06-2008, 02:34 AM
JIM's Avatar
JIM JIM is offline
Default 69 70 Corvette 350 Smog system early take off !
For sale a untouched original 69 Corvette 350-300 HP smog set up. This will also fit a 350 Hp by changing the pulley. Completely untouched the clamps have never been loosened. The pump is dated 171 of 69 the clamps 1/69 this was on a late built 69 so it could also be used on an early 70 car too.. It was removed in 1972 and has been in storage since, pump spins freely and it has the correct white fan . All of the mounting brackets are intact with the system. This is complete bolt on system pump,pulley,spacer, brackets, divertor, hoses, check valves and pipes
$ 900.00
Please call Jim at 302-420-4743
Thanks SYC
