Old 08-05-2008, 03:47 AM
firez firez is offline
Default 302 Z28 oilsending unit thread
Does anyone know what thread the oil sending unit hole is? I am trying to put a sending unit in but the threads are built up with crap and I want to put a tap down through to clean it up.
1968 LOS Rallye Green Z28
Old 08-05-2008, 05:11 AM
Default Re: 302 Z28 oilsending unit thread
1/8th national pipe tap. Its a tappered thread. Put some grease on the tap itself and hopefully it won't drop all the little filings down the block. You could also spin the oil pump and refresh the sending unit hole with fresh oil before you start the motor up.
Old 08-05-2008, 06:41 AM
Thanks for the help,it seems a 3/8 NF 24 is very close also.
Old 08-05-2008, 03:41 PM
TDW TDW is offline
Whatever you do, do not use the 3/8" tap. It will destroy the taper in the hole.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 08-05-2008, 04:57 PM
Thanks for that help but I think that is what has been done already before I bought the car. Do you know if a heli-coil will work to fix this problem?
Old 08-05-2008, 05:37 PM
TDW TDW is offline
I have never heard of a heli-coil for a pipe thread. I would check the auto-parts store for a straight adapter that is 3/8"-24x 1/8" NPT. There are fittings like that in the brake tubing/fitting cabinets around here.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
Old 08-05-2008, 07:42 PM
I found a local machine shop that will make me up a adapter that will work with the problem I have encountered. Thanks Tony
Old 10-28-2008, 09:07 PM
PaulK PaulK is offline
FYI - Future reference
They DO make a 1/8 NPT helicoil. McMaster Carr #91733A401 with tap #91711A251. Also 1/8 NPT is 27 TPI.
Old 10-29-2008, 03:49 AM
TDW TDW is offline
Thanks Paul. I stand corrected then.
Tony
55 Nomad Gasser
70 SS 427 Nova
Michigan/ Florida
