Old 07-30-2008, 08:28 AM
TXSS TXSS is offline
Default A Little Different ZL-1 Powered Camaro….......ZL-X
1969 Camaro. Powered by a GM All Aluminum ZL-1 427. This Camaro was built to drive, with some of the
modern upgrades a ZL-1.......ZL-X 427 Camaro might appreciate.
#1 Frame off rotisserie restoration, show quality PPG base coat / clear coat. Undercarriage is like new.
Virtually everything on this car is new or restored to like new condition.
* Exterior Color: 2009/2010 Camaro "Inferno Orange"
* Interior: Black & White Hounds-tooth (kept as stock as possible)
* All Aluminum GM ZL-1 427 / 535 hp (stock trim)
Block 3946053
Intake 3933198
GM Aluminum Heads 3946074
Holley Carburetor 4296
7115 GM Steel Crank
TRW Pistons
Correct ZL-1 .620 lift mechanical cam
* T56 Tremec 6 Speed (.62 6th gear)
* Hydraulic Clutch
* Custom Fab Moser M9 Rear End 3:73 Gear
* Power Rack & Pinion Steering
* Aluminum Radiator w/ Duel 1500 cfm Elec. Fans
* 4 Wheel Wilwood Power Disc Brakes
* Global West Tubular A-Arms
* QA1 Coil Over Shocks
* DSE 4 Point Roll Cage
* DSE Mini-Tub 3 inch Drop
* DSE Low Profile Sub-Frame Connectors
* Vintage Air Front Runner A/C System
* Rock Valley Stainless Steel Gas Tank
* Front 7X18 Coys C5 with Kumho ECSTA MX 235/40
* Rear 10X18 Coys C5 with Kumho ECSTA MX 275/40 (built to run 335/30's)
* Rear Set of Kumho ECSTA MX 335/30's come with the car
* Stock Appearing Blue Light Radio AM/FM/XM/iPod
* Stewart Warner Green Line Gauges
115,000.00
Additional Pictures can be seen
HERE
Rick
