Old 12-22-2025, 01:04 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Originally Posted by Arrowsmith View Post
Hood? Probably an original air box L88.
Schwing!
Jake Dykstra
Dykstra Motorsports
The Following User Says Thank You to RPOLS3 For This Useful Post:
Arrowsmith (12-22-2025)
  #82
Old 12-22-2025, 10:43 AM
Smile
[QUOTE=RPOLS3;1685428]Schwing![/
Thanks! Way back when (geez…50 + years ago…Yikes!) that was the plan on my blue LS6, although I never got to it. I think it will be a good look but boy, hoods were sure cheaper then
The Following User Says Thank You to Arrowsmith For This Useful Post:
RPOLS3 (12-22-2025)
  #83
Old 01-02-2026, 07:36 PM
Smile MSD Mount
Completed a small project over New Year’s day: I fabricated a mount for the MSD box (actually I fabbed two because I made a mistake on the first one…”no job is worth doing unless you can do it twice”….L-O-L). Anyway, the idea was to install the MSD box in the same location as the recently removed charcoal vapour cannister.
First things first: I sprayed the cannister fastener heads with black paint and immediately transferred that to some card stock.
I made a pattern and taped it to a ¼-inch thick piece of black plastic (similar to nylon) sheet I had in my parts stash.
The sheet was roughed out with a hacksaw and then trimmed with files.
Corners were checked with a small square….
And then deburred with 80 grit and 320 grit sand paper.
I rounded the corners too. Here’s the finished basic ignition board. FYI, I use this same process with all MSD mounts, but some are much larger than this.
Here’s the Ultra 6AL mounted on the board.
With the side grille removed from the Corvette fender, access is awesome. You can see the three OEM holes for the charcoal cannister. I wanted to use the same holes basically because I hate drilling into a car unless it’s absolutely necessary. BTW...you can see more evidence of what the Corvette is like here....Even though the car has had its share of challenges, I'm pretty much over the moon with it. I've owned and worked on some really nice clean cars over the years, but this one is the best by a long shot...
Here’s the board installed. I used aircraft AN fasteners for the install.
The Ultra 6AL was test fit before I removed it. The reason is, I have no need for all of the features (and wiring) in this particular box. I’ll use the “less fussy” Ultra 6A. It doesn’t have a start retard, three rev limiters, step retard and more.
Done. I can go back to tinkering with the console. It presented some challenges. I’ll show the progress down the road.
W
The Following 10 Users Say Thank You to Arrowsmith For This Useful Post:
cheveslakr (01-10-2026), dykstra (01-03-2026), L78_Nova (01-04-2026), napa68 (01-03-2026), olredalert (01-02-2026), PeteLeathersac (01-02-2026), RPO LS7 (01-02-2026), scuncio (01-02-2026), Tenney (01-04-2026), Xplantdad (01-11-2026)
  #84
Old 01-03-2026, 12:58 AM
napa68's Avatar
napa68 napa68 is online now
I love your work Wayne
Arrowsmith (01-03-2026)
  #85
Old 01-03-2026, 01:16 AM
Smile
Thank you. If we were closer I’d buy ya a beer!🍺
napa68 (01-04-2026)
  #86
Old 01-10-2026, 03:41 PM
Smile A little progress...
I haven’t done anything major on the Corvette, but I did take care of a few things:
First things first. One place I didn’t check for blunders was the wiper system at the cowl. No surprise, I found some loose fasteners – some that were basically started by one thread and then untouched. I fixed those, but in the process, I also removed the cowl vent panel.
One of the eight machine screws that affix the cowl vent panel was obviously stripped. Here’s the “restorer’s” fix. Body caulk on a cheap machine nut (his version of a lock nut…L-O-L):
There was no way to re-tap the threads larger and still have a screw head small enough to fit within the vent for installation. My easy fix is this (AN ½-height lock nut):
Then I went back to work on the center console. I didn’t like the previous owner’s version of detailing the big die cast console piece. I couldn’t come up with a clean fix plus the “restorer” used lacquer (without primer) for the repaint. If you looked at the console wrong, it would scratch. So, I replaced it with a new piece from Trim Parts. It’s a really (Really!) nice reproduction. While I was at it, I added a more appropriate console data plate and a new soft leather shifter boot. The old boot is hard as a rock.
I had a real dilemma getting the heater control to fit cleanly. Under the heater controls is a stamped steel bracket that sandwiches between the console and the heater control. It also incorporates the vent control levers. I spent a lot of time pondering it. As it turns out, the previous owner had bent the steel bracket. It took me a number of tries to get it right but I eventually had success. While I was at it, I replaced the plastic slides that guide the vent levers. Not shown: I have fresh, fresh air vent knobs to install.
Once the time comes to reinstall the console, it will have to be partially disassembled, but after a week or two of fiddling with it, I’m pretty confident I can get it apart and together one more time…L-O-L.
I’ve shown this before, but here’s the complete e-brake console section (complete with power window switches).
I’m slowly inching forward. So far so good. I’m confident, considering the train wreck it was originally, the Corvette will turn out nicely.
Right now, I have to wait for my budget to catch up. I’m pretty sure others can relate. 
W
The Following 14 Users Say Thank You to Arrowsmith For This Useful Post:
69M22Z (01-10-2026), big gear head (01-10-2026), Dave Rifkin (01-12-2026), dykstra (01-11-2026), L78_Nova (01-12-2026), napa68 (01-10-2026), olredalert (01-10-2026), PeteLeathersac (01-10-2026), RALLY (01-11-2026), Roger M (01-11-2026), RPO LS7 (01-10-2026), RPOLS3 (01-12-2026), Tenney (01-11-2026), Xplantdad (01-11-2026)
  #87
Old 01-11-2026, 06:28 PM
RALLY RALLY is offline
Just great workmanship Wayne, thanks for sharing.
The Following User Says Thank You to RALLY For This Useful Post:
Arrowsmith (01-11-2026)
  #88
Old 01-11-2026, 08:44 PM
----That console is better than any of the 21,801 71 Corvette consoles as delivered from the factory, Wayne!....Bill S
  #89
Old 01-11-2026, 09:21 PM
Smile Thank you...I'm humbled
Thank you both for the compliments. I've said this before, but I always think I can do better and I really do believe there are any number of forum members who are much better at this than me. I can only hope to get to that level.
My goal with the car is to build the very nicest Corvette (roller) I can. And then sell it (much to my adult daughter's chagrin!). The reason is, I want to build one last go-fast car. I have a desire to build another 1969 Camaro - this time for pure stock muscle car drags. I believe I have one more big build left in me, but age is certainly entering the equation and I'm sure that some will understand.
Anyway....thank you again. I am most definitely humbled.
Wayne
The Following 5 Users Say Thank You to Arrowsmith For This Useful Post:
L78_Nova (01-12-2026), olredalert (01-11-2026), PeteLeathersac (01-12-2026), RPO LS7 (01-12-2026), RPOLS3 (01-12-2026)
  #90
Old 01-12-2026, 07:33 PM
Smile Little things...L-O-L
Major sigh of relief...
Awhile back (when I still had a budget...L-O-L) I took a leap of faith and bought a set of new, but shelf worn headers for the car. Hooker Headers has offered 2.125-inch X 3.50-inch, under car headers for big block Corvettes for a long time. Actually had them on my original LS6. But a year or two ago, they abruptly discontinued them. I found this set in California and I'm delighted. . They arrived today. Score!
Forgot: There are absolutely zero 2-1/8-inch under car headers available today for C2 and C3 big block Corvettes today, aside from Lemons Headers, but the Lemons jobs only fit automatic cars.
The Following 7 Users Say Thank You to Arrowsmith For This Useful Post:
big gear head (01-13-2026), dykstra (01-12-2026), L78_Nova (01-12-2026), napa68 (01-14-2026), RPO LS7 (01-14-2026), Tenney (01-13-2026), Xplantdad (01-12-2026)
