Old 03-06-2025, 10:27 PM
MarcDant's Avatar
MarcDant MarcDant is offline
Always good to see these cars revitalized especially cars with family pedigrees, congrats you've almost reached the finish line. Thanks Marc.
The Following 4 Users Say Thank You to MarcDant For This Useful Post:
dykstra (03-06-2025), napa68 (03-07-2025), PeteLeathersac (03-07-2025), RPOLS3 (03-07-2025)
  #342
Old 03-07-2025, 02:00 AM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Seeing Tim's 67 L79 engine compartment pictures motivated me to get to work after I got home this evening.
I was able to get the under hood engine compartment pretty well buttoned up tonight after getting everything I needed rounded up this afternoon. I took off the header bar and had the painter get that while he did the radiator yesterday. He also did the fan shroud and air cleaner assembly. Last year I put a new fan clutch on the correct restored fan blade so that still looks good. The generator rebuilder took the generator apart and re-sprayed the case as it had a bunch of scratches in it since he rebuilt it a few years ago. Filled up the radiator with new anti-freeze and distilled water and installed some new decals while I was at it. Waiting for a few small things yet but getting pretty close now.
Final brake bleed (I've got fluid at all 4 corners) and front brake adjustment and I think I'm done..............for now.
Jake Dykstra
Dykstra Motorsports
The Following 13 Users Say Thank You to RPOLS3 For This Useful Post:
67since67 (03-07-2025), big gear head (03-07-2025), BJCHEV396 (03-07-2025), dykstra (03-07-2025), Hawkeye (03-07-2025), L_e_e (03-07-2025), napa68 (03-07-2025), olredalert (03-07-2025), PeteLeathersac (03-07-2025), Roger M (03-07-2025), SS427 (03-08-2025), Tenney (03-07-2025), Too Many Projects (03-07-2025)
  #343
Old 03-07-2025, 02:10 AM
Just WOW.
The Following 2 Users Say Thank You to Lynn For This Useful Post:
dykstra (03-07-2025), RPOLS3 (03-07-2025)
  #344
Old 03-07-2025, 02:27 AM
67since67's Avatar
Double WOW!! That is spectacular!!
Jake, this car must, no HAS to be at MCACN 2025!!
The Following 8 Users Say Thank You to 67since67 For This Useful Post:
dykstra (03-07-2025), napa68 (03-07-2025), olredalert (03-07-2025), PeteLeathersac (03-07-2025), RPOLS3 (03-07-2025), SS427 (03-08-2025), Tenney (03-07-2025), Too Many Projects (03-07-2025)
  #345
Old 03-07-2025, 03:33 AM
BJCHEV396's Avatar
Wow,you're doing really well! Keep the pics coming!!
The Following 3 Users Say Thank You to BJCHEV396 For This Useful Post:
dykstra (03-07-2025), PeteLeathersac (03-08-2025), RPOLS3 (03-07-2025)
  #346
Old 03-07-2025, 11:44 AM
napa68's Avatar
napa68 napa68 is offline
I'm with Bill^^^^^^
The Following 4 Users Say Thank You to napa68 For This Useful Post:
67since67 (03-07-2025), dykstra (03-07-2025), PeteLeathersac (03-08-2025), RPOLS3 (03-07-2025)
  #347
Old 03-07-2025, 11:51 AM
scuncio's Avatar
scuncio scuncio is offline
Nice work! Engine bay looks flawless.
The Following 3 Users Say Thank You to scuncio For This Useful Post:
  #348
Old 03-07-2025, 11:55 AM
Tenney Tenney is offline
Diggin' the details, Jake - that's one lucky car!
The Following 5 Users Say Thank You to Tenney For This Useful Post:
dykstra (03-07-2025), olredalert (03-07-2025), PeteLeathersac (03-08-2025), ragtop (03-07-2025), RPOLS3 (03-07-2025)
  #349
Old 03-07-2025, 08:36 PM
----Your Dad is looking down right now and knows that every last thing is done to perfection, Jake. Can't wait to see cousin Eddie's masterpiece with the Dykstra's touch at MCACN!!!....Bill S
The Following 6 Users Say Thank You to olredalert For This Useful Post:
dykstra (03-07-2025), PeteLeathersac (03-08-2025), RPOLS3 (03-08-2025), scuncio (03-09-2025), SS427 (03-08-2025), Tenney (03-08-2025)
  #350
Old 03-09-2025, 03:11 AM
RPOLS3's Avatar
Made some more progress today.......
My wife helped me final bleed the brakes first thing (remembering when my Mom helped my Dad do this when I was too young to help). I also installed the upper ball joint rivet bolts. The first set I ordered the rivet top wasn't wide enough to seat properly with enough contact area on the ball joint so I bought some from the Corvette vendors and I think they are much better. Not sure why this is a big deal to me other than I like the more correct look of the rivet top. Also final adjusted the front drums and installed the anti-vibration springs around the drums - they come off much easier then they go back on. Thoroughly washed and dried both sides of the wheels and tires prior to re-installing. I left the hubcaps off in case I needed to take the wheels off again for some reason - plus I'm scared to death to put them on and risk damaging them.
I had about an hour left before I needed to call it quits for the day and figured oh what the hell let's get it on the ground and go for a test drive. So I started it up and burped the radiator and topped off the anti-freeze and once it was warmed up I backed it out of the garage and tested the brakes on the way down the driveway......so far so good. Our roads are still heavily salted from some winter weather last week so I kept the drive short and just ran around the block in our subdivision. Never got out of second gear and made a few hard stops to make sure I didn't have any major issues. Luckily all went well and other than a few minor things (oil filter canister gasket leak and lower radiator hose leak at the clamp) I think we're good. It doesn't pull or make any odd noises when braking at the relatively low speeds I tested at, it has a rock solid pedal, and I was actually surprised how well it stopped. (It will never be confused with a modern Corvette........) When the roads get cleaned off better I will extend the trip to outside my subdivision and test at higher speeds.
Getting close now............
https://youtu.be/-4DujKMXeZ8]
https://youtu.be/5SSpEuwc8LU
Jake Dykstra
Dykstra Motorsports
The Following 11 Users Say Thank You to RPOLS3 For This Useful Post:
67since67 (03-09-2025), Bill Pritchard (03-09-2025), BJCHEV396 (03-09-2025), dykstra (03-09-2025), L_e_e (03-09-2025), napa68 (03-09-2025), olredalert (03-09-2025), PeteLeathersac (03-09-2025), Roger M (03-09-2025), scuncio (03-09-2025), Too Many Projects (03-09-2025)
