Old 04-30-2005, 01:54 AM
JoeG JoeG is offline
Default Re: DZ Spark Plugs?
Sam --Rob did performance comparison tests on the dyno and he said he saw the difference with the NGK's performance.I've got an electronic ignition so I can open the gap or file back the ground rod a bit and my unit will fire pretty hot.----- I've got no complains with AC, BUT dynos don't lie, Rob said it performed super. I did however find that the AC 44 or 45 did keep a "STREET TUNE" longer than the NGK IN MY CASE-- also AC 43 is a little too cold if your not gonna blow out the carbon now and again....----------I would guess Rob would be able to give you a number for your Z............
Old 04-30-2005, 02:02 AM
Thanks Joe. I am thinking about using some of my NOS AC 44's for the street. (AC's look better) I have been using Autolites with good results. Maybe the NGK's are even better??!! Need to get the right heat range for the NGK. Thanks!
Old 04-30-2005, 02:12 AM
Chevy454 Chevy454 is offline
Here is what NGK shows for the '69 Z28: CLICK HERE
I'm personally not up on the small block NGK plugs, but our dyno guy should be...
Old 04-30-2005, 02:13 AM
Yeah they do look better--guess it's a sentimental thing........
Old 04-30-2005, 02:45 AM
Thanks Rob! Sam
Old 04-30-2005, 03:25 AM
DarrenX33's Avatar
Thanks Rob! Sam
I second that thanks!
1969 Z28
1972 Corvette
Old 04-30-2005, 04:48 AM
Belair62 Belair62 is offline
Marlin/ Frank...what jets are you running front and rear ?
Old 04-30-2005, 05:31 AM
NGK
Old 04-30-2005, 06:14 AM
John Brown's Avatar
www.rockauto.com/ 3332/XR5 NGK $1.61 each, comes in 4 pack.
John Brown
Old 04-30-2005, 06:33 AM
budnate's Avatar
budnate budnate is offline
never heard of them..John you order from them on a reg basis???
