Old 04-26-2007, 07:30 PM
3macs1 3macs1 is offline
Default Re: Flywheel
Even if it did fit. What would the starter snout look like. You would be lucky to get the busHing in not much more.
Old 04-26-2007, 11:46 PM
The "621" measures 16 3/4" and the "403" is 16 1/4" That 1/2" is why the 11" flywheel will work only in the 621 & 444 bellhousing. Kim
OK...I spoke too soon saying it would fit, the flywheel #3791021 is a 153 tooth wheel and is a smaller diameter than the 168 tooth wheels which came with both 10.5 and 11 inch PP's. Which BH does the L78 that started this post have?
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
Old 04-27-2007, 01:21 AM
firstgenaddict's Avatar
The starter snout for the smaller beelhousing has the straight across bolt pattern like a Monza with a V8 or the 67-69 Z28.
The snout for the larger flywheel has the staggered pattern... we just went through this with the Black 69 Rs/Z when we put the motor back in with the stock sized flywheel in it
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 04-27-2007, 02:00 AM
What I want to do is put a 10.5" setup on a BB with a 403 BH. I thought the starter opening in the BH was the same size?
Old 04-27-2007, 02:26 AM
Hi Marlin:
I for one would not use a 10 1/2 inch clutch behind a l-78 but everyone has their own way of doing things.Those doing it with no problems please chime in.I guess I just like my feet too much and would worry maybe not justified with a 10.5 taking on all of that HP, but that is me.
Here is the differences in the openings for the starter.
621
403
I agree with james on the starter snouts but remember the 403 using a very small end cast iron snout with the cross bolt pattern which is not common.Might be with you z-28 boys but I had a hell of a time finding one when I used this combo on a 292 chevy.
Hope the pictures help.
Old 04-27-2007, 04:37 PM
I thought the L88 'vettes used a 10.5" setup?
Old 04-27-2007, 07:24 PM
L78steve L78steve is offline
I believe you can use the 10.5/403 set-up on the big block.But the problem will be a shorter clutch life.I used a 10.5 on a torquey 350 and went through clutches rather quickley.I then changed to a 11" set up and it solved that problem.
Old 04-27-2007, 07:25 PM
I Think the ZL-1 also used the 403
Jake is my grandson!!
Old 04-27-2007, 08:01 PM
The one I have out of a 69 L-88 is a 621 11". There may have been some applications for the 403 with a BBC in 65/66 but I remember 99% of 403's being installed with small blocks vetts and z-28 and the BBC getting the 621's.
Old 05-08-2007, 08:12 PM
Can someone decode this part # for me? 3791021 I'm told it's a 10.5" flywheel applicable for a #403 bellhousing.....
