Old 04-06-2007, 06:15 AM
myhot69 myhot69 is offline
Default Re: Mega Parts List #2
Bob, you are one of the verry few that has it right, it dont matter i cant spell or type.
Old 04-07-2007, 09:29 AM
Here is all thats left, until i dig into the last pile that is
* 69 chevelle/camaro/nova original disk brake callipers L&R set #s 637 & 638 working with dot3 fluid 3 mos ago and pulled to install dot5 fluid 50.00 for the pair
* 71 Chevelle front bumper bracketts, i belive these are correct for 70-72? 25.00set
* Camaro/Chevelle/Nova SB Heads # 3932441 SB dated E 19 9 & F 19 9 Need rework but came off a running engine I had and drove (ben dry in my garage 10+ yrs) 150.00set
* Headlight Bucketts and rings from 69 chevelle good cond. no rust, set of 4 2sets 15.00set
* Manley 100 thousants longer pushrods for BB with Dart heads, intake side 8.450 X 3/8 # 25845 4130 swedged end pro series 8pc in orig box 20.00
* 69 Chevelle/camaro/nova RH SB exhaust manifold # 3932376 dated A 7 9 great cond. with orig studs and flapper no heat sheild 40.00
* 69 Chevelle/camaro/nova RH SB exhaust manifold # 3932376 dated CorG? 2 9 great cond. with orig studs and flapper w/heat sheild but loose 40.00
* 69 chevelle AC elbow shutoffs for ball vents L&R 2 sets 20.00set
* 69 chevelle AC ducts 2 or 3 of every one under the dash email me with a description of the ones you need.
* 68 chevelle/camaro/nova BB quadrajet intake cast iron # 3883948 dated L 28 7 for 68 car 50.00
* Tag Flip down holders for 69 camaro/chevelle GM original part with #s on back 2pc 20.00ea
* 69 chevelle SS396 dash strip above glove box 70.00 has a verry small place in corner but good driver quality
* 68-72 chevelle wiper arms 2sets 20.00 & up per set
* 69 ElCamino smugglers box cover (bolts to bed) 20.00
* BB stock rods and caps from 325/350HP bigblock 3/8 bolts good cond. 25.00
* 67-69?camaro (came out of a 69) fiberglass wheelwells used but in good condition 50.00 for set will try to work out shipping if you cant pickup but there big
* 68-69 Chevelle front fender braces (bottom front to rad support) 1set 20.00 per set
* metal headliner trim L&R set from 69 chevelle 3 sets 30.00 per set
* non tilt floor shift stering collum 69-72 chevelle with key complete and tight 50.00
* rear seat from 70-72 chevelle good foam and springs need covers will try to work out shipping 50.00
* rear view mirrors all from 69 chevelles but are the same on 68-72 chevelles, camaros? 5pc 10.00ea
* emergency brake foot pedal assembally 1 from 70-72 chevelle 1from 68-69 chevelle 20.00ea
* 69 chevelle tail light housings with good studs 2 sets 25.00 per set
* vent ball assemballys pass side and drivers side 3 of each side 10.00ea
* kick pannells 3 sets of AC blue from 69 chevelle but will fit 68-72 AC 40.00
* 69 chevelle speedo cables all used from 69 ss 4 pc 15.00 ea
* Loads of small parts from 69 chevelle inside and out just email me and ask
* 69 chevelle dash bezels better than average condition have 3AC 40.00 and up
* 69 chevelle heater workings inside of car Non AC have1 50.00ea AC have 3 45.00ea
* heater controls 69 AC have2 20.00 69 non AC have120.00ea 71 AC have 1 20.00
* 70 - 72 chevelle door window regulators both sides 25.00
* 69 - 72 chevelle buckett seat headrests, good condition saddle colored but can dye 50.00
* 69 chevelle jack assembally Not numbered on staff or base but has 69 chevelle hook and lug wrench 40.00
* 70-72 chevelle under stering collum cover, green but can be painted to match interior 15.00
* 69 chevelle probubly 68 too AC style gove box compartment (not broken) 20.00
* 69 camaro Z-28 waterpump # 3953692 dated F 20 9 50.00
* window regulators 4 for each window of a coupe 69 chevelle 20.00ea or 50.00 for set of all 4 windows
* complete set of 4 original deep dish SS caps and retainers good driver quality but replate for show 50.00
* SB cast iron 300 hp intake # 8927184 dated J 18 8 50.00
* BB cast iron intake 325 or 350 hp 396 # 3931067 dated F 19 9 50.00
* BB Left exhaust manifold for # 3892307 dated K 23 5 Impala 396 and 427 20.00
* 69 Camaro or 70 Chevelle standard stering wheel center with horn buttons Blue in good condition (leather grain) (had 1 verry small crack but repaired verry nicely) 20.00
* 4 speed guage housings NO GUAGES just the plastic for a 4 speed car 2pcs 15.00 ea
* 70-72 chevelle AC vents center vent - passenger lower dash vent - drivers lower dash vent with stering collum cover 50.00 all
* Upper control arms for 68 - 72 chevelle 3sets 30.00 set
* hidden wiper metal windshield trim (under wiper blades when parked) 4pcs 20.00ea
* door weatherstriping crome (around door glasses) 4 sets 20.00 set
* 69 chevelle headliner rods 4 sets 20.00 set
* 69 chevelle headliner metal pcs that flexable headliner surround trim hooks on 3 sets 20.00
* 71 chevelle metal headlight extentions (Bolts to fenders and holds parklights) 20.00for the pair
* 69 chevelle wiring harnesses, AC but will need to look at condition depending on your car
* 68-72 auto crossmembers 4 auto 25.00
AND MUCH MORE EMAIL ME FOR YOUR NEEDS Thanks
Old 04-07-2007, 06:16 PM
chevelleheart chevelleheart is offline
Darryl , did you ever get that pic of the 69 -70 SS steering wheel ? Thx , don't mean to rush you , I know you have a lot of stuff and a ton of emails to reply to,..It's just a gentle reminder . Thx Bob
Lately into Beaumont SD's, 66,67,68 and 69 , including a 69 2 Dr Post Beaumont , an L78 2 Dr Post Chevelle LS6 Chevelle's, LS6 and L78 El Camino and Camaro fan ! Also 2 Cdn Documented COPO's, a COPO Camaro and COPO Chevelle Love GM Products
Old 04-08-2007, 12:05 AM
Pics are on the way to your email address
Thanks Darryl
