Old 03-20-2007, 11:51 PM
Default Re: Cannister Filters
Double gaskets or a piece of crud are common causes...but I know there is no crud on your cars..so maybe it's the gaskets...good luck
wilma
Old 03-21-2007, 12:49 AM
Double gaskets is a very common error. One gets stuck up inside of the block. Good thinking Wilma!
Old 03-21-2007, 01:58 AM
ORIGLS6 ORIGLS6 is offline
That was one of my first thoughts too Sam. But.....
"I forgot to mention that this is on the Rebuilt Engine that just went back in the Chevelle"
Old 03-21-2007, 02:57 AM
One of these days I'll have a car that doesn't leak oil................
Hmmm...this from a guy who DRIVES all of his cars....
Old 03-31-2007, 06:43 PM
Have you inspected the cannister adapter after removing it?
It's unusual,but I had a similar scenario,and after basically doing what's already been recomended,found the adapter had a harline crack in it.
I would replace the adapter.
Old 04-01-2007, 02:56 AM
kwhizz kwhizz is offline
After a couple of start and drive cycles, it seems to have sealed itself up ....Not a Drop anywhere.......I finally have a car that does'nt drip Oil..........
Ken
Old 04-01-2007, 02:58 AM
JoeG JoeG is offline
Probably out of oil.......................
Old 04-01-2007, 07:51 AM
Denis Denis is offline
Old 04-01-2007, 06:58 PM
3macs1 3macs1 is offline
As the old GM mechanics used to say if your BBC is not using a little bit of oil you are not driving it properly.
