Old 02-22-2007, 06:57 PM
Norm reynolds Norm reynolds is offline
Default Re: Gas siphoning
I tell what I use and it works pretty good
87-91 fords I know the vans had them . A electric fuel
pump that was mounted on the frame rail likes like a fuel filter with wires
I take one of them attach a small fuel line on the suction end of the pump and
Attach the outlet hose in a gas can put suction hose in the gas fill hole power up the pump with 12 volt’s
I can get 98 % of the gas out that way have been doing
this for years
But for god shake do not use your mouth to Siphon Have learned the hard way
This is NOT a good thing to do
For me it was the best way
Old 02-22-2007, 07:30 PM
budnate's Avatar
budnate budnate is offline
a little tip cowboys, grab a outboard gas squeeze bulb insert in your siphon line.. pump a few times...wollaa gas... and no bad breath later on your date, dont ask how I know this trick.
I came up with the idea of using clear line after NUMEROUS incidents of coughing and gagging on Hi-Test!
I imagine it gave you gas...you could probably light your burbs on fire...now that's a party trick...
Old 02-22-2007, 07:39 PM
ORIGLS6 ORIGLS6 is offline
Yeah, that works too........ or one of those cheap squeeze pump thingys we used in the 80's to fill our Kerosun Heaters.
Old 02-22-2007, 07:43 PM
jl8z28 jl8z28 is offline
go to Home depot and get a kerosean pump and take the siphon line and put it on the end to make it longer, it will empty your tank in no time.
Old 02-22-2007, 07:52 PM
camaromb camaromb is offline
There is a great product available for siphoning. Its a long section of 1/2" clear hose with a check valve on the end. Its called the super siphon. It was a gift, I'm not sure where they are sold but it works great.
Mark
Old 02-22-2007, 10:47 PM
Ngtflyr Ngtflyr is offline
Super Siphon
Much better than the tried and true method I learned when I was a kid.
Dave
Old 02-23-2007, 12:23 AM
PeteLeathersac's Avatar
I did an upside-down head inside the empty doghouse of a 60's Chevy Van siphon trick once...sucked on the fuel line and filled my head and sinus cavity w/ gas...puked, passed out and had a headache for days...don't try it!!.
On another Danger note, isn't Ethanol toxic if you ingest it?. I've seen some station pumps note up to 10% Ethanol content and wondered how bad ingesting some when doing the simple siphoning we all love to do?.
~ Pete
Old 02-23-2007, 12:48 AM
Alss's Avatar
Alss Alss is offline
Thanks guys..used a siphon pump on the fuel line by the fuel pump..did the trick nicely!!..of course I took too much out and had to put it back in again
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 02-23-2007, 04:04 AM
GRB GRB is offline
If you can get your hand around the filler neck hole you can put your fingers over the hole so that when you blow into the hose you increase the air pressure in the tank so that when you take your mouth off the hose the fuel comes squirting out. That's scientific! Kind of like letting the air out of a balloon.
