Old 04-29-2005, 08:54 PM
Default Re: DZ Spark Plugs?
I just pulled out the Original Factory AC 4 green ring R43T's yesterday in my trailer queen,and installed NGK UR5's,per Robs advise.
HOLY CRAP! It feels like I added 10 more Horse Power with a much better start up & a responsive throttle as never before.
You should see how Fouled my old R43T's look.
Thanks Rob & Marlin
Lifes too short to stare at your Car..
Old 04-29-2005, 09:06 PM
Chevy454 Chevy454 is offline
I've been trying to tell you folks...I think more people would be surprised if they'd just give 'em a try...you AC folks just don't know what you're missing!
BTW: what did you end up paying for the NGKs up your way?
Old 04-29-2005, 09:14 PM
Belair62 Belair62 is offline
I couldn't get R43 or 44 for that matter...I put a set of some kind of platinum Bosch plugs in it and it seems to run pretty good. What number NGK for these LT1's Rob ?
Old 04-29-2005, 09:19 PM
DarrenX33's Avatar
Yeah I'll go for a change. What is the 44 equivalent?
1969 Z28
1972 Corvette
Old 04-29-2005, 09:37 PM
I called all the local Auto parts stores here,most said they would have to order the NGK #UR5,&amp; are $2.80-3.25 a plug.
I found ONE local NAPA store that had 8 on the shelf for $1.76 each,so I drove over to pick them fast as opposed to waiting a few days &amp; paying more to the others.
I have no idea why this one store had my plugs in stock,and for so much less?
Neither did the store clerk.
(By the way Rob,NGK Technical hotline does not show my 1970 396/291 head application,they kept saying I should use the 840 head application &amp; gave me the NGK equivalent number.I told them to update their records as the 1970 L78 is a 291,not 840 head. )
Old 04-29-2005, 10:01 PM
I use R45's for the street and cruising, but re-install R43's for SCR racing - remember the spark plug delivery to the meet-n-greet in the parking lot by the local Chevy dealer?
I have fouled several sets of R43's, (not my NOS set of 4 thin lined ones though), and found that the hotter R45 worked much better. I will give the NGK's a try though, as the R45's will foul occasionally too, especially after idling in line at a cruise or a show.
Old 04-29-2005, 11:01 PM
budnate's Avatar
budnate budnate is offline
NGK's trick is to find them for a couple bucks a plug..we used to get them from Al's for about what Rick picked his up for then Chucks bought them out...now there back up to 5 to 8 bucks a plug...we need to find a online place to get them priced fairly...throttle response with them is usually real good.
Old 04-29-2005, 11:44 PM
DarrenX33's Avatar
NGK appears to have a million different indentifiers for their plugs. How the heck did you decode UR5 for your L78. My car decodes to B6S for an R44. With the middle number being the heat range 5-6-7. 6 being middle. replacement.
1969 Z28
1972 Corvette
Old 04-30-2005, 12:43 AM
JoeG JoeG is offline
Rob had mentioned these... web page
Old 04-30-2005, 01:38 AM
Are NGK that much better than the Autolites? Whats the # for the 69 Z's? Thanks, Sam
