Old 04-08-2025, 04:33 PM
Originally Posted by hogdaddy View Post
What torque are you using.
Here is an interesting thread.
https://www.camaros.net/threads/plea...ip-nuts.83635/
I saw that too. Crazy it’s from 2006 and still having the problem in 2025.
They stripped before I could get a torque wrench on them. The originals I cleaned and put back torqued to 25ft/lbs with no issue.
Old 04-08-2025, 04:37 PM
hogdaddy hogdaddy is offline
Are yours the CIP clips or other? Where did you get them?
67 Convertible T-1
Old 04-08-2025, 07:02 PM
Not sure the brand. I can look closer tonight. They came with the install kit from Eaton Spring
Old 04-08-2025, 07:52 PM
Honestly, I could have sworn my 67 originals were the barrel style but could be mistaken.
AMK fastener sold them at one time.
http://www.camaros.org/forum/index.p...67281#msg67281
67 Convertible T-1
Old 04-09-2025, 12:12 AM
Too Many Projects's Avatar
Too Many Projects Too Many Projects is online now
The original clip nuts on my '67 Feb LOS built are hex. I have a set of the replacements from OER and the bolt seems under-size, as it wobbles in the barrel and the threads are shallow in the barrel as well. I can see where they aren't going to hold much torque.
One of my original bolts cross threaded in a nut too and the bolt is trash. I was going to use 1 replacement clip nut and bolt, but not now. I will re-thread the nut, but will need a bolt, as the replacement bolt is loose in the original nuts too.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 04-12-2025, 02:26 AM
There is no brand identifier on the j clips
