Old 10-30-2017, 11:50 PM
TAR6569 TAR6569 is offline
Does the XI car have a posi?
381 and counting in the 67-69 Impala SS427 registry
Old 10-31-2017, 12:37 AM
SS69chevelle SS69chevelle is offline
The two build sheets with XI and L78 I have are both posi, KK coded rearends.
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
Old 10-31-2017, 10:17 AM
I have not seen the car in person, but from what I have seen yes it is a KK rear end and posi.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
70 Z28 4 spd 4th owner CA car Citrus/Green Cloth
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 10-31-2017, 10:23 AM
Originally Posted by SS69chevelle View Post
Checked several of the build sheets and portions and they seem to only use the codes below for the four speeds. the other codes may be used but I do not have any examples of them.
XC- M20 L48, L35
XG- M20 L35
XF- M21 L78
XI - M22 L78
take care, Andy
My car is a Framingham car with a build sheet, original engine (L78) XD in box 29, bench seat. Clearly a manual from new but I don't know if it could had been a three speed? The shifter is a Hurst not a Muncie, and the gauge carrier is for a manual car. The column is not from a column shift car. The tunnel has torch marks like on a Camaro for a 4 speed, but, I don't know if Chevelles had the same torch marks on the hump like Camaros did or not?
Any other XD codes in box 29 on Framingham build sheets?
69 Z/28 RS (Sold)
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
Old 10-31-2017, 02:20 PM
Viz Viz is offline
Originally Posted by sixt9rsx33 View Post
Thanks Viz...My 69 Chevelle L78 has the XD code, but the original tranny is long gone. So assuming it was a M-21. I saw a build sheet on another 69 L78 Chevelle with a M-22 and it was coded XI. Both Framingham cars. Viz is your car a Framingham built car?
Would like to know what all the codes stand for on the build sheet similar to what you can find for Mopar. I only have a partial build sheet for my car. The left side of the sheet that shows up to box 96.
Yes, mine is a Framingham built car. Also, box 29, Axle, is KF for the 355 G80 Posi.
Viz
