Old 07-29-2016, 12:38 AM
RST's Avatar
RST RST is offline
Default Re: 1970 455 W30 Dyno Results
[/quote]
Scott -- When I bought my 69' W-30 442, one of the selling points was the advertised "select-fit" 400 engine ... is this what you are referring too above? Thanks ... TAZ [/quote]
Taz, not sure what you mean ............. what I am saying is, that with Kenny's build using stock parts, but &quot;his&quot; blue print, we picked up about 12% more HP over the factory build ....... Yes, the factory did &quot;Select Fit&quot; builds on curtain motors ... however, a master engine builder doing a perfect blue print can gain about 10-12% HP increase over stock or &quot;Select Fit&quot; factory [img]<<GRAEMLIN_URL>>/smile.gif[/img]
1968 1/2 Cougar 428 R Code, Cobra Jet, 4 SPD, Red Interior in restoration at MASCAR to be unveiled by Kevin Marti at the MCACN 2020
1970 Top Secret Very Special Muscle Car in restoration by MASCAR to be unveiled at MCACN 2020
Old 07-29-2016, 12:41 AM
earntaz earntaz is offline
Agree -- much difference between &quot;select-fit&quot; and a &quot;blue printed&quot; engine ... TAZ
Old 08-01-2016, 09:59 PM
Crossbreed383 Crossbreed383 is offline
Block decking/cyl head milling. chamber equalized, correct cam lift and rocker ratio verified, oil control, degree cam, carb tricks,etc
Results are nice and not out of line of what should be normal numbers for a non factory,assembly line type rebuild
Even with all this , shows what these dinosaurs need to even try and make 1 hp per cubic inch
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
Old 08-03-2016, 11:14 PM
black69 black69 is offline
to add to the value of blueprinting, there is a nice booklet that bill thomas did on taking apart the 65 L78 for a vette, and redid it to ideal specs and got 500HP out of it (vs the 425 spec).
75HP gain just by getting everything perfect. A little more than a 15% gain.
