Old 01-03-2018, 03:06 PM
enio45 enio45 is offline
You see vapor blasting associated with motorcycle resto shops for some reason.....
Results are amazing - vapor blasting on brass and copper is WOW!
I used it a lot on the ferrari restoration - uses ultra fine media, chemical agent and water under pressure. We did alt cases, trans cases and believe this is the ticket. Tumbling works well also, but you get the media marks in the metal which gives that unique sheen. Remember that on 4 sp cases, it seems that all the alum seem to be of different grade, thus the finish on each is a little different.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-03-2018, 03:07 PM
Jim, your muncie case looks great....
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
The Following User Says Thank You to enio45 For This Useful Post:
McCune (01-03-2018)
  #13
Old 01-08-2018, 01:50 AM
crash crash is offline
I've seen alot of the re-skinning and tumbling and wheelbrater Muncie castings and they all look nice, but when you put them side by side with an NOS Muncie trans or NOS Muncie castings they're different colors and texture/smoothness...
As far as the black coating on the bolts goes, not all the bolts holding a Muncie together have the black coating, it depends on the supplier at that period in time...
In the early years most bolts were natural, later on they used some coated bolts...
I have an NOS 1969 M-21 only the front bearing retainer bolts are coated...
So to sum things up as nice as all this looks, its getting close to being over restored...
Hope this helps... Crash
The Following User Says Thank You to crash For This Useful Post:
Schonyenko2 (01-09-2018)
