Old 01-30-2015, 07:18 PM
firstgenaddict's Avatar
Default Re: Z28 firewall I.D.
LA cars usually have stripe color over spray on the firewall if you scrape some of that black paint off there should be stripe color on the cowl top and down the firewall, obviously if the stripes were black it is more difficult to discern.
The LA cars I have seen also have the color in numerical code vs color written, I assume this is because they built different car lines in LA and some colors were coded the same yet carried different names?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 01-30-2015, 09:10 PM
al8apex al8apex is offline
true ^
That is the easy way to determine the 1st gen "real" Z28's / Z-11/10 cars as long as no one has removed (stripped / sand blasted) the paint off the top of the cowl
as shown in the above pics, Van Nuys painted the entire upper cowl in strip color
Jim R
Scottsdale, AZ
Old 01-30-2015, 09:32 PM
69VN's Avatar
69VN 69VN is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Zman1969</div><div class="ubbcode-body">engine mount #s Z/s and SS350?? use same engine stand but not other SBCS also check length if pitman arm the Z's got fast ratio should be 5.8&quot; long for fast ratio
from David Pozzis site:
POWER LONG 5.8&quot;, 3953237
POWER SHORT 5.25&quot;, 3935711 </div></div>
In 1969 both the Z/28 &amp; the SS350 shared the same engine frame mounts...left side #3945507 right side #3945508. Original stampings should be on them unless they were changed at some point.
Sal
Old 01-31-2015, 09:36 PM
ds1 ds1 is offline
1969 350 Camaros not just SS used the same motor mounts.
1967 Camaro conv (first car)
1969 Camaro street car
1967 Super Stock SS/JA Joe Scott car
Old 02-02-2015, 05:33 AM
Kurt S Kurt S is offline
Yup. Mount info: http://www.camaros.org/engine.shtml#EngineMounting
Kurt S - CRG
