Old 05-29-2014, 12:08 PM
m22mike's Avatar
m22mike m22mike is offline
Default Re: 12 bolt spring perches
Yes, 2*, or 88* off 90. The repop perches must be relieved some where they fit the axle tube. I fixed one hack job on a 69 Camaro with the reproduction perches. Had the axle housing upside down with the leaf springs held in place with the front and rear diamentions secured with some wood strips to act as a guide.
I think the repop ones are good, but they lack some detail, like the stiffening indents on each side.
Old 05-29-2014, 07:24 PM
68z28kk 68z28kk is offline
I found something on ebay that might help out in your search for perches. This auction is for a 10 bolt housing with what looks like multi leaf perches. The seller would probably cut the tubes and send the perches to you and scrap the rear axle housing. If the perches are correct for your axle it is worth a try. http://www.ebay.com/itm/1970-81-Cama...50&vxp=mtr The price is hard to beat and its close to you. I have a pair of perches but they were welded onto a '69 Chevelle rear end so it would be a major job to get the excessive welds cleaned up. Clint
