Old 07-30-2013, 05:07 AM
ban617 ban617 is offline
Default Re: Hurst shifter handle
Is there a number on the muncie shifters to tell what they fit? I think I have a couple but will need rechromed and rebuilt....
Old 07-30-2013, 12:51 PM
AutumngoldL78 AutumngoldL78 is offline
Bill.I bought one of these from gup.Hope it helps.
http://www.ss396.com/mm5/merchant.mvc?Sc...=SHIFTERHANDLES
Micheal
Old 07-30-2013, 01:43 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: AutumngoldL78</div><div class="ubbcode-body">Bill.I bought one of these from gup.Hope it helps.
Micheal </div></div>
Micheal, the Nova handles are different than Chevelles. When the Nova shifter handle comes out of the shifter, it turns to the right, to get it farther away from your leg, so just cutting a handle off and drilling new holes, doesn't work. That's why others have talked about grafting the new handle to a Nova handle. Also the Chevelle handles are bigger, and I have to be careful which handle to use, because they can hit the dash.
69 El Camino
69 Nova
C7 Vette
Old 07-30-2013, 02:12 PM
JoeC JoeC is offline
It works if you cut off the Muncie stick below the offset on the bench seat stick.
There is a bushing welded on that has to be removed also and some grinding has to be done. Welding on the lower piece to the Hurst stick will work also.
The one in the pic here was not cut off in the right place as they cut off the offset part.
On the 67-68 Camaro I just match the Muncie stick to the Hurst 4106 stick.
The 4106 stick is also used on 1968 Nova with console
there are some on here for 67-68 Camaro and 1968 Chevy II (Nova) with console
http://www.camaros.net/classifieds/s...52&amp;cat=500
Old 07-30-2013, 06:38 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bill Rose</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: AutumngoldL78</div><div class="ubbcode-body">Bill.I bought one of these from gup.Hope it helps.
Micheal, the Nova handles are different than Chevelles. When the Nova shifter handle comes out of the shifter, it turns to the right, to get it farther away from your leg, so just cutting a handle off and drilling new holes, doesn't work. That's why others have talked about grafting the new handle to a Nova handle. Also the Chevelle handles are bigger, and I have to be careful which handle to use, because they can hit the dash. </div></div>
They also sell splined shims to move it over.I might have some shims left over from when i bought the hurst/muncie kit.
Have you looked at Hurst's website?
Old 07-30-2013, 06:49 PM
JK
Old 07-31-2013, 01:43 AM
Zman1969 Zman1969 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jasonL78</div><div class="ubbcode-body">Bill this is what you need to do.
Find an old shifter handle cut off the bottom and weld on the hurst bottom.
Just did it for Tom Williams a couple months ago.
The second shifter is the one he gave me to use as a template.
Of coarse I had to grind my weld dowm.
</div></div>
Jason, what model car was the Muncie shifter handle out of? I plan on this on my 69 Nova.
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 07-31-2013, 03:24 AM
Thanks again for the replies gentlemen. I've looked at a bunch of handles. I've been swamped the last couple days getting stuff done on the Nova, and getting the truck, trailer and El Camino ready for the trip to the Ohio Chevelle show. I'll deal with the shifter when I get home. Thanks again for all the replies. Lots to think about......maybe I should have stuck with the powerglide??
69 El Camino
69 Nova
C7 Vette
