Old 08-03-2012, 02:29 AM
jl8z28 jl8z28 is offline
Yenko Premier Member
Default Re: 4 Sp cross member to the subframe
there not the ones for the Camaro, the ones that HB City have are a close reproduction
Old 08-03-2012, 02:41 AM
Hello Jason,
There are many one year only bolts on the 1968 Novas. This is one of them. 69-70 were most like the 69 Camaro.
I am always surprised how many little differences there are in 1968's.
Greg
Old 08-03-2012, 03:02 AM
enio45 enio45 is offline
Hummmm, logically the flanged head make sense due to the fact it has to be inserted thru the frame, so a socket type tool is necessary to hold the bolt as its inserted into the hole.
HBC bolts, have the one side washer for the slotted holes on the crossmember, but the bolts i believe are not correct if you buy my theory as stated above. WOJ's bolts look to to have the flanged head to me?
Any one from CRG listening?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-03-2012, 10:26 AM
Woj's Avatar
Woj Woj is offline
Ed,
The pix of the bolt Jason posted are the same as the ones installed on my Camaro. Same head markings too.
If Mike did not send you pictures, let me know. Mine are fairly rusty, but the detail can still be seen.
I agree that the flange makes sense due to the location and positioning.
Phil Woj.
Old 08-03-2012, 12:33 PM
m22mike's Avatar
m22mike m22mike is offline
For you hardware freaks.. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
Here are the pictures of Phil's subframe bolts, car has never been messed with. Cleary shows washer head bolts. Second photo shows the use of a flat washer under a split washer. This detail was only use on the r/h 2ea. bolts that are on the side of the crossmember that has the two slotted holes. The reasoning should be obvious. These bolts are not called out in the 69 AIM, most likely the crossmember was already bolted to the frame from the vendor.
Old 08-03-2012, 01:50 PM
Nice detail shots of an original assembly. Thanks for sharing Mike.
Old 08-03-2012, 02:20 PM
jasonL78 jasonL78 is offline
Wow from the multiple pm's I have gotten I wish I had several sets. LOL! But I only have 3 bolts and 1 that can be made correct for a full set.. If Eddie don't want them then I will offer them to the first PM I got. AS for a price I have no idea. I was just trying to help a member out.
Looking for the next project.
Old 08-03-2012, 03:54 PM
Very very interesting - thanks mike and Woj for the pics.....need to check AMK to see if they have right head markings....i know they have the correct flanged bolt - need to check the head markings
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-03-2012, 05:22 PM
Based on Phils pic and the number of threads sticki ng up past the nut, with the washer and the lock washer, the bolt length is 1 1/8th with a flanged head.
This would be the case for both sides - length is the same.
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-03-2012, 05:46 PM
m22mike's Avatar
Eddie
I would not be to concerned about the head markings, GM always had multiple hardware vendors. I saw a survivor 69 a few years ago the had three different vendor marks on the four trunk lid bolts.
You say they are about an 1 1/8&quot;, I will look in my extra stuff.
Mike
