Old 02-26-2025, 01:50 PM
Smile 1971 Corvette Hot Rod Build
My NCRS Top Flight '71 Corvette has been in my hands for a week. I've had a chance to go over it and figure out what I'm doing. It became crystal clear the car has to come apart. Not only were the fasteners loose on the rear camber adjusters, the left hand exhaust is falling off loose, some of the bumper bolts are loose (ditto with a number of other parts -- some critical), the shocks (original) are soft, the steering box weeps at the pitman seal and car wet itself.. ....the rear main seal leaks. This explains the wonky clutch. In the end I found roughly 3 dozen things that need attention and I haven't had the car up in the air long enough to have a really close look.
With that in mind, I've decided to blow the thing apart and check everything. And while I'm at it, the plan is to build it into a mild, stock appearing hot rod.
Given that plan, I'll have a pretty good chunk of original parts for sale down the road. That includes an engine, two sets of wheels and tires (one set 1971 correct with almost new 54 year old tires), interior parts, exhaust parts and so on. If you have a "want list", keep me in mind!
Here we go....
The Following 11 Users Say Thank You to Arrowsmith For This Useful Post:
69M22Z (02-26-2025), 69Z11Pacer396 (02-26-2025), Chuck_Burg (02-26-2025), dykstra (02-26-2025), Hawkeye (02-26-2025), jerry455 (02-26-2025), L78_Nova (02-26-2025), napa68 (02-26-2025), PeteLeathersac (02-27-2025), Stihl (12-22-2025), Tenney (02-27-2025)
