Old 09-05-2015, 10:24 AM
ZLP955's Avatar
ZLP955 ZLP955 is offline
Default Parts ID
Need your help to ID the original application of a few bits and pieces that I have no use for, and confirmation if it's all junk or any of it could be useful to someone:
1) Cooling Fan, includes clutch unit: stamped 916322 C76 498579. I have an idea this came off a Pontiac but not sure......
2) Saginaw Power Steering Box, casting number 5691676, Julian cast date of 223 and assembly date on cover 230 5. I know these were used on many GM platforms, but not sure if it'd be a 1965 or 1975 assembly date.
3) Saginaw Power Steering Box, casting number 7826692, Julian casting date of 24, can't find an assembly date.
4) Delco Remy starter motor, stamped 1108430 3K24. I think I pulled this from a 'vette a long time ago.
5) Delco Brake Master Cylinder, casting number 5470408, 1 1/8 bore, Julian casting date of 183 or 193. Also has brass brake combination valve. Removed from a 69 Camaro but i think it's a 70's GM application.
6) 11" Brake Booster, has Delco Moraine stamp but right way up at 2 o'clock when installed. Can't make out 4-digit code on front of top tab, but stamp on rear looks like 'CL' rather than a number.... came off same 69 Camaro as item 5. Was painted black at some point and now partly stripped to bare steel.
Any help would be much appreciated.
Thanks, Tim
Tim in NSW, Australia
Old 09-07-2015, 06:20 AM
ZLP955's Avatar
Default Re: Parts ID
Is there a more appropriate forum sub-category for this question?
Old 09-07-2015, 03:44 PM
As for the starter, my books only go up to '73 and its not listed. The 1108 numbers seem to start around '68, so that one must be a '73, Oct 24th for a '74 model. IT's definitely NOT a '63 starter.
Old 09-07-2015, 04:41 PM
John Brown's Avatar
My old NCRS book shows 1108430 used on 70 to 72 Corvette all 350 engines with Turbo Hydra-Matic, but with that date your getting into the 74 area like Verne said. I guess it is possible they used the same starter part number in 1974 though.
John Brown
Old 09-07-2015, 07:00 PM
JohnZ JohnZ is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: John Brown</div><div class="ubbcode-body">My old NCRS book shows 1108430 used on 70 to 72 Corvette all 350 engines with Turbo Hydra-Matic, but with that date your getting into the 74 area like Verne said. I guess it is possible they used the same starter part number in 1974 though. </div></div>
The 1108430 starter was used on 350 auto Corvettes from 1970 through 1975; that one was made in October '73 for '74 production.
[img]<<GRAEMLIN_URL>>/burnout.gif[/img]
'69 Z/28
Fathom Green
CRG
Old 09-08-2015, 12:24 PM
ZLP955's Avatar
Thanks guys, really appreciate the help on the starter motor.
Doesn't seem like any of it would have much appeal; was thinking of offering the lot for free on the pay-it-forward thread, but the shipping would no doubt prove too costly.
Unless any Aussie/NZ members need anything?
