Go Back   The Supercar Registry > Events > Auctions
Old 03-02-2021, 05:35 PM
Lee Stewart's Avatar
Arrow 1970 Chevelle LS6
https://www.mecum.com/lots/SC0521-46...-chevelle-ls6/
Attachments - The Supercar Registry tn_10018655.JPG Picture 248.jpg IMG (23).jpg Chevelle.jpg
Old 03-03-2021, 03:05 PM
----To the next owner, please lower that car......Bill S
COPO (03-04-2021), ORIGLS6 (03-03-2021)
Old 03-03-2021, 04:13 PM
I would love to know what exact springs people are using to get them to sit correctly. As of late we have had nothing but trouble getting these cars to sit down where people like to see them. I have 4 cars in the shop and all 4 sit at this height. ALL have original assembly line springs in them on all 4 corners. Two of them still had the tags on them when they came in as well as original assembly line shocks but sit high. I have tried several different Moog springs and am now onto trying Eaton springs. We have also done all the math with the vendors to try and resolve it and have a TON of money in both labor and spring cost and have not been able to get them to sit right. Been doing this for 40 plus years and these last 4 cars are killing me.
The Following 4 Users Say Thank You to SS427 For This Useful Post:
Damien (03-05-2021), John (03-04-2021), Ryan1969Chevelle (03-03-2021), Xplantdad (03-03-2021)
Old 03-03-2021, 07:37 PM
Ryan1969Chevelle's Avatar
That is very strange.
I had to read your note twice to make sure I understood correctly...….
Did the 4 cars sit nice and low when they arrived unrestored?
My car sat perfectly nice and low when I got it and I reused the original springs an it sits the same now...…… I'm really puzzled Rick, keep me in the loop!!
Control arm bolts tightened when the suspension is up as high as possible? I am not going to have any suggestions for you as I have 1 year of experience and you have 40 :-)
Ryan W.
Old 03-03-2021, 08:09 PM
Originally Posted by Ryan1969Chevelle View Post
That is very strange. Did the 4 cars sit nice and low when they arrived unrestored?
Ryan W.
They all sat a little lower but not by much and still higher than most would like to see. I cannot stress enough, all had original 50 year old worn out coils and two cars had original shocks.
We tighten the suspension when the car is a rolling chassis and no body. We then pull it down while on a 4 post hoist using ratchet straps and take measurements where prescribed in the book and then tighten all the bolts. I have been doing it this way for years. I am really getting frustrated as it is prohibiting me from delivering some of these cars.
I just received my Eaton coils about and hour ago and they are 2" shorter than the other 4 original sets so we shall see where that puts it. If that works then I have to figure out how to lower the fronts the same amount but should be easy using the same formula. Just a pain to have to tear four front ends apart to replace front coils.
The one pictured looks good but is still about 1.5" too high.
flyingn (03-03-2021), olredalert (03-04-2021), RPOLS3 (03-03-2021), Ryan1969Chevelle (03-03-2021)
Old 03-04-2021, 05:53 PM
If you pull the car down with straps and then tighten the bolts doesn't that just put a strain on the bushings as they are trying to return to neutral all the time ?
The Following 2 Users Say Thank You to Charley Lillard For This Useful Post:
John (03-07-2021), ORIGLS6 (03-26-2021)
Old 03-04-2021, 08:13 PM
dustinm dustinm is offline
What I believe they are trying to do here is have the bushings at a neutral state/ ride height when tightening.
You are correct they will wear out faster if bound up on install, but with these cars even if they cheat them are they going to see enough miles to even break in?
Old 03-04-2021, 08:24 PM
Jamess113's Avatar
Jamess113 Jamess113 is offline
I have been using Hotchkis 2" and 3" drop springs to get a nice ride height. This Judge has a 2"drop spring.
Jay.
Auto Body Specialists
1966 L79 Chevy II Super Sport 4404 miles
1969 Pro Touring Camaro
1970 Nova Pro Touring Project
http://www.autobspec.com/
https://www.flickr.com/photos/abscla...oration/albums
The Following 4 Users Say Thank You to Jamess113 For This Useful Post:
BLACKLS5 (03-04-2021), GearheadSS (03-12-2021), John (03-07-2021), olredalert (03-08-2021)
Old 03-04-2021, 09:50 PM
That is correct. Tighten when the chassis is fully assembled with no body but pulled down to it's ride height. When the body is lowered onto the chassis it 'should' settle at its neutral position. Would tightening be better after the car is on the frame? Yes but it is VERY hard to get at the two bolts above the muffler. Also, the factory set the ride height on the chassis before the body was mounted from everything I have read so I am only repeating what was done originally.
The Following 2 Users Say Thank You to SS427 For This Useful Post:
John (03-07-2021), PeteLeathersac (03-05-2021)
Old 03-05-2021, 12:37 AM
Damien Damien is offline
I tried 2 other sets of front springs for my Chevelle before trying the set of 2" lowered fronts springs I had sitting on the shelf for 3 years.
Never thought they would be the answer but I think it's pretty close.
1969 SS 396/350 Chevelle
