Old 02-14-2008, 10:28 PM
YENKO DEUCE REGISTRY's Avatar
Default TCS Switch
Here's the TCS switch for the trans sidecover, a bit pricey though starting out at $500!
Anyone know if this one is still available from GM? #3961567.
http://cgi.ebay.com/ebaymotors/1970-Nova...sspagenameZWDVW
Marlin
Old 02-14-2008, 10:55 PM
Default Re: TCS Switch
Still showing available, 3961567 dealer cost $6.92 wholesale $9.12 and list at $12.14. The new switches aren't cosmetically exactly like the original assembly line part but I guess that would depend on how fussy you want to be.
Chris
Old 02-14-2008, 11:28 PM
Good to know. I found an old NOS one when I did my resto, I think I paid about $10 for it. I don't the old versions are worth the $500 yet, are they?
Marlin
Old 02-15-2008, 12:52 AM
Rixls6 Rixls6 is offline
You might try using part number 3996286 to search for the earlier style. They sure aren't worth $500, but tough to find NOS.
Rick
Don't text and drive.
Old 02-15-2008, 01:36 AM
Rick,
The 286 switch you show is harder to find as it is discontinued. The only problem is it is a later model year application. Yours is a spade type switch while the 567 is a pin type. 1970-71 use the pin type and some 71 and all 72 models use the spade. You would need to modify the harness to use the 286 switch on a 70-71 car.
Chris
Old 02-15-2008, 02:22 AM
Chris is correct, the '70 Deuces indeed use the pin type switch.
Anyone know the part number of the side cover that holds this switch?
Marlin
Old 02-15-2008, 02:57 AM
Rick,
Chris
Thanks for the info Chris.
Rick
