Old 01-12-2007, 05:35 AM
MosportGreen66's Avatar
Default heater hoses
I'm just about done with the '58 Fuelie Vette I've been working on for the last month. The heater core was bypassed when I get the car although a new heater core was installed. I'm having trouble installing the new, reproduction heater hoses. Is there is a trick-of-the-trade I should try or know about?
The heater hose in-let to the water pump is the unit I'm having most specific problems with. I've tried grease and even heat. No luck,
Thanks!
-Dan
Old 01-12-2007, 10:42 AM
PeteLeathersac's Avatar
Default Re: heater hoses
If you can spare losing a bit of length, sometimes you can cut the end on an angle creating a larger opening and work it on...then recut it straight after. .
~ Pete
Old 01-12-2007, 04:45 PM
TDW TDW is offline
Any chance the adapter in the pump is the wrong hose size?
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 01-12-2007, 05:44 PM
Yes. That is what happened. Our Corvette part supplier has sent us more wrong parts than I could ever imagine. I guess the typical zero-error business standard does not apply to Corvette parts
