Old 03-06-2005, 02:52 AM
SS454 SS454 is offline
Default SS wheels help
Hi would like some help with wheel codes for ss wheels. They read 4 9 YA the 4 is on the left side of valve if looking from the top then comes the 9 than the YA. Would like to know what these are for. Thanks
Rick
I can send a picture if you need to see it i tried to post a picture but did not work.
Rick
69 RS Camaro NOT Working on it for now!!
Old 03-06-2005, 02:59 AM
Default Re: SS wheels help
Thats the Date code.
4=month,April
9=day
YA=Application code for SS Camaro-Nova-Chevelle-Elco.
Look to the left of the 4.You should see a M with a small number next to it.Thats the MFG. code,example M4 for Motorwheel.
Look under it to determine year rim was assembled.
Example=M4/8...8 is for last digit of year,1968.
Full YA assembled code is April 9th,1968 from Motorwheel.
Old 03-06-2005, 08:54 AM
Thanks for the help mr 70. It has M 1 Than a 9 under the m1.
So these wheels should be for a 1969? Thanks again for your help.
Rick
Old 03-07-2005, 08:46 AM
CROSSRAMJL8 CROSSRAMJL8 is offline
DOSE ANYONE KNOW WHEN THE SS WHEELS CAME INTO PRODUCTION AND WAS OFFERED ON CAMAROS
Old 03-07-2005, 03:54 PM
The only year Camaro received these wheels was on the 1969 model.
Colvin says the earliest SS 14X7 YA Magnum wheel found to date is 11/4/68.
When you type in Capitol letters,it means you are yelling.
Can you please not yell so often.
Old 03-11-2005, 07:23 AM
Mark_C Mark_C is offline
No one has ever come up with a documented Camaro (build sheet, window sticker, shipper copy, or GM of Canada documentation) that shows the SS wheels were installed as an option on a 69 Camaro.
Mark C.
My Pace Car
