Old 07-27-2016, 11:05 PM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
Default 1970 455 W30 Dyno Results
I thought I would share my results on a recent build. This engine is the original engine for our Black W30 four speed. The specs are 100% original except for a half point lower compression. and a complete blueprint. Ran with the stock camshaft,intake, carb and exhaust manifolds.No tuning on the QJet just a quick timing loop. Timing didn't seem to matter between 31 and 36 degrees.
With stock manifolds.
TQ@ 3800 485 HP@ 5200 410
With Headers
TQ@ 3800 514 HP@ 5400 441
Ken Maisano
Old 07-27-2016, 11:19 PM
wundercluck wundercluck is offline
Default Re: 1970 455 W30 Dyno Results
Wow nice work Ken! They do appear to like the headers...
Don
Old 07-28-2016, 12:13 AM
Nice. What was the original compression ratio?
Old 07-28-2016, 12:18 AM
Ken...WOW!
Old 07-28-2016, 12:19 AM
Stefano Stefano is offline
Just a bit of Maisano Magic.
.....Nice work!
Just goes to show that the 370hp rating by OLDS was a bit understated, while the 500tq was close.
Old 07-28-2016, 04:22 AM
RST's Avatar
RST RST is offline
Stefano, you know I love you, but I will disagree, the factory numbers were very close if not dead on. This is a result of a master engine builder doing a proper blue print, and assembly. I am sure you will agree as others, that a proper blue print and assembly in most cases can be, as we see here, at 10-12% increase in power. Problem is, there are not that many builders left that can do this with these old engines. Kenny specifically wanted to keep the motor as true to original specs as possible, the only deviation was dropping the compression from 10.5 to 1 to 10 to 1 … this is where we see the slight drop in torque, he did this to ensure no issue with 91 octane gas. We will post a video of the runs and the dyno results tomorrow.
1968 1/2 Cougar 428 R Code, Cobra Jet, 4 SPD, Red Interior in restoration at MASCAR to be unveiled by Kevin Marti at the MCACN 2020
1970 Top Secret Very Special Muscle Car in restoration by MASCAR to be unveiled at MCACN 2020
Old 07-28-2016, 02:44 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RST</div><div class="ubbcode-body">Stefano, you know I love you, but I will disagree, the factory numbers were very close if not dead on. This is a result of a master engine builder doing a proper blue print, and assembly. I am sure you will agree as others, that a proper blue print and assembly in most cases can be, as we see here, at 10-12% increase in power. Problem is, there are not that many builders left that can do this with these old engines. Kenny specifically wanted to keep the motor as true to original specs as possible, the only deviation was dropping the compression from 10.5 to 1 to 10 to 1 … this is where we see the slight drop in torque, he did this to ensure no issue with 91 octane gas. We will post a video of the runs and the dyno results tomorrow. </div></div>
Scott -- When I bought my 69' W-30 442, one of the selling points was the advertised &quot;select-fit&quot; 400 engine ... is this what you are referring too above? Thanks ... TAZ
Old 07-29-2016, 12:38 AM
RST's Avatar
RST RST is offline
[/quote]
Scott -- When I bought my 69' W-30 442, one of the selling points was the advertised &quot;select-fit&quot; 400 engine ... is this what you are referring too above? Thanks ... TAZ [/quote]
Taz, not sure what you mean ............. what I am saying is, that with Kenny's build using stock parts, but &quot;his&quot; blue print, we picked up about 12% more HP over the factory build ....... Yes, the factory did &quot;Select Fit&quot; builds on curtain motors ... however, a master engine builder doing a perfect blue print can gain about 10-12% HP increase over stock or &quot;Select Fit&quot; factory [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 07-28-2016, 10:12 AM
Ryan1969Chevelle's Avatar
Serious numbers!!!
Ready for PSMCDR:-)
Ryan
Old 07-28-2016, 02:41 PM
KenMaisano's Avatar
