Old 04-01-2016, 04:50 PM
mockingbird812's Avatar
Default Need Clutch Recommendation: '69 Chevelle L78/M21/3.73
Current clutch is a bit tired. Use will be for general cruising with occasional hard launches on the street with bias ply OEM style/size tires or 7" cheater slicks. In other words I won't be trying to hook it up on a sticky drag strip.
Thanks [img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
Sam...
Old 04-02-2016, 02:32 AM
carnut4life carnut4life is offline
Default Re: Need Clutch Recommendation: '69 Chevelle L78/M21/3.73
My transmission builer just recommended a Centerforce dual friction clutch for my 69 Camaro for the exact same driving conditons so that's what I'm planning on going with.
Old 04-02-2016, 04:15 AM
Brocca Brocca is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: carnut4life</div><div class="ubbcode-body">My transmission builer just recommended a Centerforce dual friction clutch for my 69 Camaro for the exact same driving conditons so that's what I'm planning on going with. </div></div>
I have been replacing center force clutches with Ram units. No 500 mile break in and takes a beating.
performancecarrestorations.com
Old 04-02-2016, 05:14 AM
VintageMusclecar's Avatar
Sam, is your trans fine or coarse spline?
Old 04-02-2016, 07:46 AM
Kurt S Kurt S is offline
From JohnZ:
LuK makes outstanding clutches (they're the largest OEM clutch manufacturer on the planet); you can get them overnight from Carolina Clutch (www.carolinaclutch.com) or from www.dialaclutch.com. Smooth engagement, low pedal pressure, and OEM-level reliability.
Kurt S - CRG
Old 04-02-2016, 12:08 PM
Ryan1969Chevelle's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Kurt S</div><div class="ubbcode-body">From JohnZ:
LuK makes outstanding clutches (they're the largest OEM clutch manufacturer on the planet); you can get them overnight from Carolina Clutch (www.carolinaclutch.com) or from www.dialaclutch.com. Smooth engagement, low pedal pressure, and OEM-level reliability. </div></div>
This is what I have for my W-31, but I haven't experienced using it so I am hopeful it works well but couldn't recommend LuK yet........ When I was asking for opinion I think Centerforce, Hays Street Strip, and LuK all got votes from several very experienced guys who have Abused them seriously:-)
Ryan
Old 04-02-2016, 12:35 PM
LuK makes outstanding clutches (they're the largest OEM clutch manufacturer on the planet); you can get them overnight from Carolina Clutch (www.carolinaclutch.com) or from www.dialaclutch.com. Smooth engagement, low pedal pressure, and OEM-level reliability.</div></div>
Put one in my camaro (Luk) with NO issues. I Run L60 Mickey's and dump the clutch on occasion and have no problems. Been over a year now. Feels like the factory clutch which was tuff to beat when new in 69. I love soft pedals. Don't really think you need dual this and dual that. Never had them back in the day and I know 95% of the people do not drive em like they stole em anymore.
Old 04-02-2016, 01:05 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Kurt S</div><div class="ubbcode-body">From JohnZ:
Put one in my camaro (Luk) with NO issues. I Run L60 Mickey's and dump the clutch on occasion and have no problems. Been over a year now. Feels like the factory clutch which was tuff to beat when new in 69. I love soft pedals. Don't really think you need dual this and dual that. Never had them back in the day and I know 95% of the people do not drive em like they stole em anymore. </div></div>
I have an LUK in my Corvettes with no issues, but did install one in my Gold 69 RSZ and had to switch it out because of a faulty pressure plate that came with the clutch. Put in a center force and I like it better than the LUK setups. The pedal pressure is lighter and there is a noticeable adhesion difference in my opinion. I have also heard RAM clutches are as good as centerforce and cheaper.
65 Corvette Coupe L78
69 L71 Roadster Survivor
69 Z/28 RS (Sold)
69 Dodge Charger R/T
70 W30 442 Auto Air Survivor
2016 Z06 Coupe M7
70 AAR Cuda (Sold)
69 L78 Chevelle (Sold)
Old 04-02-2016, 01:03 PM
Good stuff. Thanks for all your input. Eric, I'm not sure - I've never pulled the tranny. I think it can be figured out though. Can the experts weigh in on what an M21 going to a 3.73. posi in an 06A built Chevelle should be?
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Sam...
Old 04-02-2016, 01:29 PM
Eric - Two sources indicate a '69 M21 (my trans is original to the car) would have a 10 spline input shaft.
Sam...
