Old 10-25-2013, 03:46 PM
Alss's Avatar
Alss Alss is offline
Default steering column grommet
anyone have a source for the grommet? for the reverse light and steering lockout for a 69?..the tab at the end of the column at the bottom..hooks up to the backdrive linkage..seems to be hard rubber?..Thanks
Albert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 10-25-2013, 08:53 PM
Alss's Avatar
Default Re: steering column grommet
Update. Seems manual vs auto use a different grommet. Auto is thick, while manual is thinner. Need one for a manual...have a auto to trade [img]<<GRAEMLIN_URL>>/smile.gif[/img]
Old 10-26-2013, 01:06 AM
Alss's Avatar
heres pics of the difference:
manual:
auto
thickness difference is about 1/8 inch
Old 10-27-2013, 02:10 AM
For anybody who may be able to help Albert, here's a few pictures of what he needs. GM part # 391312 for the steering column grommet with manual trans. Has a few unique features that make it fairly easy to identify. There are letters ABF cast into the rubber and a center brass bushing for the upper backdrive rod. Inside the groove that mounts it to the steering column is a wavy pattern cast into the rubber.
Hopefully somebody has a spare for Al.
Old 10-27-2013, 12:43 PM
Alss's Avatar
thanks Chris
Old 10-27-2013, 09:29 PM
69VN's Avatar
69VN 69VN is offline
I hope this is what you need Al. The bushing in this one appears to be plastic... but here's the link:
http://www.heartbeatcitycamaro.com/s...-bushing-1969/
SAL [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 10-27-2013, 09:33 PM
Alss's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69VN</div><div class="ubbcode-body">I hope this is what you need Al. The bushing in this one appears to be plastic... but here's the link:
SAL [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] </div></div>
you da man!! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img] [img]<<GRAEMLIN_URL>>/[/img] [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Old 10-28-2013, 01:10 AM
Chris - ROCKS!
Old 10-28-2013, 12:55 PM
twertsy twertsy is offline
YearOne has it
