Old 01-22-2013, 10:30 PM
YENKO DEUCE REGISTRY's Avatar
Default Door hinge pins
Any tricks to removing the lower hinge pins? Would like to rebush the door hinges to align the fenders / frame.....
Marlin
Old 01-22-2013, 11:37 PM
Default Re: Door hinge pins
They make a tool for that.
Old 01-23-2013, 12:16 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Schonyenko2</div><div class="ubbcode-body">They make a tool for that. </div></div>
I have the hinge pin removal tool, but the lower pins just won't budge - it's at the point where I'm concerned what I'm mushrooming them because of all of the hammering! Wrong tool?
http://www.eastwood.com/media/catalog/pr...27b0/p23671.jpg
I liked the post &amp; pics of the Chevelle pin removal, but the Nova hinges aren't quite the same.
Marlin
Old 01-23-2013, 06:03 PM
Did you soak it good with penetrating oil? Is the top one still in enough so that you're not getting a bind? Have you moved it at all?
Old 01-23-2013, 04:25 AM
BlueSS454's Avatar
BlueSS454 BlueSS454 is offline
Send a message via AIM to BlueSS454
Here is a post I wrote on Team Chevelle when I rebuilt the door hinges for my convertible. I hope they are helpful.
http://www.chevelles.com/forums/show...;postcount=172
http://www.chevelles.com/forums/show...;postcount=173
Tom Rightler
Vice President, Maryland Chevelle Club
MCC Newsletter Editor
1970 SS 454
1970 SS 454 Convertible
1969 Malibu
Old 01-23-2013, 11:10 PM
Did not spray it all. Top one is still in, so no bind. It has not moved at all, [img]<<GRAEMLIN_URL>>/frown.gif[/img] I'm thinking of unbolting the hinges from the body and finding a way to grind the top off the pin, (?).
Marlin
Old 01-23-2013, 11:34 PM
jasonL78 jasonL78 is offline
Marlin I have found it is just easier to remove the hinge from the car and then the door. But before you remove the hinges drill a 1/8 hole in each hinge top and bottom so you can relocate them with a dowl pin. Or you can scribe a line around the outside of the hinges to relocate them. I have that door pin removel tool kit and it is useless on Novas. You just can't get the right angle to give to tool a good hit with a hammer. Good luck...
Looking for the next project.
