Old 01-10-2013, 02:26 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default '69Z body broadcast question
Is this clear enough for someone to tell me if it is a factory cowl hood car and where that code may be located on the sheet please? thanks in advance
Old 01-10-2013, 05:17 PM
danachevroletfor1967 danachevroletfor1967 is offline
Default Re: '69Z body broadcast question
The photo isn't really large enough to see the sheet clearly. On my Chassis Broadcast Copy for my '69Z there is a box, #180, that says air cleaner. If it has an 07 in this box the car came with an open element air cleaner (no cowl hood). If there is a DG in this box the car came with cowl induction. Hope this helps.
Old 01-11-2013, 12:55 AM
William William is offline
Camaros built with ZL2 as an option have the code stamped on the BBC just under the Zone & dealer info at the bottom left. A Z/28 would have 5ZL2AA there.
COPOs don't have it because ZL2 was included. They would have, for example, 9561AA.
Old 01-11-2013, 07:12 AM
Kurt S Kurt S is offline
Box 86 (next to the Y55 battery) is 07, open element - flat hood.
Interesting that the body # is blank. ??
Going thru the sheet, I see some possible problems. I'd like to see a clearer copy of the sheet before I call foul, but I'll call suspect....
Kurt S - CRG
Old 01-11-2013, 10:44 AM
Tracker1's Avatar
car is on ebay
http://www.ebay.ca/itm/290842233931?...#ht_685wt_1151
Old 01-11-2013, 11:00 AM
Does it matter about the hood Des?
Old 01-11-2013, 01:03 PM
Tracker1's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">Does it matter about the hood Des? </div></div>
Don't see broadcast sheets for '69 Zs very often, like to know the codes and layout. But yes, I prefer cowl hood cars.
Old 01-11-2013, 01:29 PM
----I can see why you find the hood suspect as the wire up to the flapper is MIA in the pics. Makes one wonder.......Bill S
Old 01-12-2013, 01:50 PM
parkbrau's Avatar
parkbrau parkbrau is offline
Dont see many broadcast sheets on Norwood cars.
Old 01-12-2013, 05:45 PM
Well, this one is a fake sheet. Very well done fake, but still a fake.
Kurt S - CRG
