Old 09-07-2009, 03:02 AM
Sportyworty's Avatar
Sportyworty Sportyworty is offline
Default Help to identify a 70 Z28
I have located a local Camaro. The owner claims it is either a Big Block or a Z28 and does not know for sure as the engine/trans are gone. It is Fathom Green, has the weld on rear sway bar brackets, 4 speed hump, 8K tack with Redline starting at 65K, The tag is unaltered but being a Van Nuys car does not seem to help. The gas pedal is cowl mounted instead of floor? It is a deluxe interior and exterior car with the moldings and tall deck wing. The car is 3,000 bucks and is very solid and thought it may be a good first GM for me. I have been trying to brush up on GM muscle here but really only know my Mustangs. I like this car but not interested if it is not a Z28 and can afford a better car just like to work on them and this would be a fun challenge?? Any tips would be greatly appreciated. Oh also it has the longer pitman arm and a 12 bolt rear.
Old 09-07-2009, 04:06 AM
MosportGreen66's Avatar
Default Re: Help to identify a 70 Z28
floor mounted gas peddle with retainer on the floor
Old 09-07-2009, 04:18 AM
TDW TDW is offline
Take a look at the lower a-frame bumpers. Z28 will have an aluminum block, about 1" thick, attached to the rubber. Like Dan said, if the pedal isn't floor mounted, it isn't a Z28. For lots of sec gen info, go to www.nastyz28.com.
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 09-07-2009, 05:28 AM
Thank you Dan, and Tony for the link.
Old 09-07-2009, 05:53 AM
John Brown's Avatar
You can also look at the pictures on Charleys site for reference. http://www.1970z28camaro.com/
John Brown
Old 09-07-2009, 04:51 PM
BARN FIND BARN FIND is offline
Sounds like a L78 with deluxe interior, if you don't buy it you should let some of the L78 Camaro guys know where it is so they can have a chance at it.
72 SS 350 4spd Camaro
74 Z28 Automatic
80 Z28 4spd
94 Z28 Automatic
