Register | Album Gallery | Thread Gallery | FAQ | Community | Calendar | Become a Paid Member | Today's Posts | Search |
Can anyone identify this odd connector?
Has anyone ever seen a connector that looks like this? I have NO idea what this is and have never seen it before. The filter looks to be simply open and pass through. The connector is nothing more than a connector. No clue why or how this got on this LS6. I have seen a lot of odd things in my years of doing inspections but this is a new one. Anyone have an idea please let me know.
Rick Nelson Musclecar Restoration and Design, Inc www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specializing in (only real) LS6 Chevelle restorations |
So the two fasteners for the pictured intake runner are studs & nuts? And the bracket for the pictured switch fastens to the rear stud? Wow Rick if this has YOU stumped, most of us are gonna be also
edit: maybe the fastener in front of the intake runner is a bolt, but it looks too shiny to be an OEM bolt.
Bill Pritchard 73 Camaro RS Z28, L82, M20, C60 Last edited by Bill Pritchard; 03-21-2023 at 09:26 PM. |
The Following User Says Thank You to Bill Pritchard For This Useful Post: | ||
dustinm (03-21-2023) |
The intake bolts, washer and stud are incorrect hardware. Its that black plastic connector between the reproduction TCS and the factory plug in harness that has me stumped.
The Following User Says Thank You to SS427 For This Useful Post: | ||
Bill Pritchard (03-22-2023) |
It looks like a resister of some sort or thermal limiter as found on some AC cars. The TSC switch used on 71 Olds had a resister tear ran across the connector on their TSC wire connector. Is this some type of fusible link.
I agree if it has Rick Stumped, who knows. Was this a CA car,high altitude? Late build/
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com |
It appears the original harness plugs into that "thing". Is the spade width different on the repo TCS and that is just an adapter ? I can't imagine it could be much of a resistor without the plastic melting..
Mitch 1970 Chevelle SS 1966 Chevelle SS 1967 Camaro ss/rs 1938 Business coupe, street rod 2000 FXSTS, original owner, 13k miles |
Not a resistor for sure that I can tell. Not a terminal adapter either.
Just a wild guess but does it fit nicely on one of the tube connectors? I'm guessing it is to allow a filtered bypass of sorts if you were to unplug the connector and slip the filter tube on one of the tube fittings. Not sure exactly why they would do this, but if it fits tightly it seems like too much of a coincidence.
70Z28 04B Norwood Forest Green-white Stripes Black DeLuxe Interior Owned since 1978 - First Car |
The factory connector plugs into this 'filter thing' perfectly and the 'filter thing' plugs into the TCS perfectly as well. When I removed it altogether the factory harness plugs into the reproduction TCS just fine like they all do. Not mine to throw away but I sure wonder why someone went to the effort to put it there when I can see absolutely no use for it.
Trick part...
Maybe it is one of those 'trick parts' they used to sell in the JC Whitney catalogs
You know...bolt this gizmo on and get more horsepower and better gas mileage. Right up there with the liquid ring job products...
02 Berger 380hp #95 Lots of L78 Novas Join National Nostalgic Nova! 70 Orange Cooler 69 Camaro |
The Following 2 Users Say Thank You to WILMASBOYL78 For This Useful Post: | ||
Bill Pritchard (03-22-2023), earntaz (03-23-2023) |
