Old 05-22-2020, 01:18 AM
earntaz earntaz is offline
Default Sun Tach
So I am going to vent a bit. During the build of the Nova, I have ordered parts -- seems like forever. After engine was installed and fired it seemed like the SST802R Sun Super Tach II was reading slow. (I can tell when an engine is idling faster than 500 RPM). Setting the timing with a pretty nice timing light that also has a tach function ... the timing light tach was indicating right a 950 RPM. So I said OK ... tach is FUBAR and I'm not dealing with it now.
So earlier this week I started to really look at this tach issue and noticed that when the ignition sw was turned on the tach did not "zero" but indicated a point approx 3/8" below the zero marking. I know darn well it is too late to remove tach, contact seller and attempt to return it as defective -- so I took it apart to see if anything was apparent to cause the low reading.
Bottom line -- as per internal makings, it is apparent the tach was made in China and whoever installed the needle on the shaft must have been in a hurry ... it was misaligned with the zero scale. Using a needle nose pliers I clamped onto the shaft and carefully rotated need back to zero position ... applied 12V and tach zeros with power on.
Cannot reassemble tach to it's original configuration as I had to "uncrimp" housing to disassemble.
End of story -- I am done venting and feel much better ... but beware of buying anything made in China ... even iconic Sun Tachometers ...
Old 05-22-2020, 01:47 AM
Lynn Lynn is offline
And it's not just tachs. It is really hard to buy quality parts these days. Had a chronic overheating problem with a brand new engine because the brand new T-stat would not open. And don't even get me started on mechanical fuel pumps.
earntaz (05-22-2020)
Old 05-23-2020, 05:36 PM
Got another "70s" looking tach -- looks much like the Sun Super and made by Bosch. Installed it and it read correctly. Guess where this fine German named item is made?
Old 05-23-2020, 09:03 PM
67 Nova Boy's Avatar
USA!!
67 Nova Boy
Old 05-23-2020, 11:20 PM
Originally Posted by 67 Nova Boy View Post
USA!!
67 Nova Boy
NOPE -- made in China!!@#$%
Old 05-24-2020, 01:13 AM
Knew that...was just playing along.
67 Nova Boy
The Following User Says Thank You to 67 Nova Boy For This Useful Post:
earntaz (05-24-2020)
Old 05-25-2020, 02:47 PM
ORIGLS6 ORIGLS6 is offline
I bought one of the Bosch half-face replica tachs for my Nova. It zeros out correctly but at 2400 RPM (actual engine revs) the tach reads 3000.
IMO they're not much more than costume jewelry.
The Following User Says Thank You to ORIGLS6 For This Useful Post:
earntaz (05-25-2020)
