Old 09-11-2023, 07:42 PM
Default Cf 1007b 1969 camaro differential
I have a 1969 Z-28 in my shop with a CF 1007B Stamped code on the right forward Axle tube and an I 27 8 cast. It has a 4:10 Posi in it with a GM carrier and a Perfect Circle gear set. I can't nor have I ever seen a CF code, What is this? Bill
Old 09-11-2023, 08:24 PM
69Z11Pacer396 69Z11Pacer396 is online now
That sounds like a Chevelle code (CCF)
Old 09-11-2023, 08:56 PM
Many Chevelle 12 bolt rear ends have been stripped of their brackets and had Camaro spring perches welded on and installed in Camaros. CF is a '69 Chevelle 12 bolt with 3.31 and Posi. It will be 61 inches wide overall, where the Camaro rear end would have been 60 inches wide.
Old 09-12-2023, 02:15 AM
60" would be backing plate to backing plate, correct? Bill
Old 09-12-2023, 02:16 AM
Does it have ears for the Chevelle upper control arms cast into the center section?
Jason
Old 09-12-2023, 11:58 AM
No. Backing plate measurements are useless. Total width is the only thing that you should be concerned with. 60 inches is total width for first gen Camaros, '68-'79 Novas and '64-'67 Chevelles. 61 inches is total width for '70-'81 Camaro and '68-'72 Chevelle.
The Following User Says Thank You to big gear head For This Useful Post:
Zman1969 (09-12-2023)
Old 09-12-2023, 03:20 PM
Jason
Good call, upon close inspection, it appears someone HAD cut off the ears and ground the housing down. This housing is from a 1969 Chevelle: CF 3:31 Posi. cast dated I 27 8. Is the CF an early (2) digit code like the (2) digit engine codes were before the 396 became a 402 and all the engine codes became (3) digits going forward? Thank You everyone for your input. Bill
Old 09-12-2023, 03:56 PM
The axle code changed to 3 digits with the 1970 model year.
Big Block Bill (09-12-2023)
