Old 09-15-2023, 12:37 PM
Arrowsmith's Avatar
Arrowsmith Arrowsmith is offline
Originally Posted by COPO View Post
Maybe I missed it, but what was the "before" db reading?
You didn’t miss it. I just fixed it. The “before” was 104.7. I edited it so many times last night, I edited it right out of there😉
Old 09-15-2023, 01:48 PM
BJCHEV396's Avatar
Great ideas Wayne,thanks for sharing bud!
The Following User Says Thank You to BJCHEV396 For This Useful Post:
Arrowsmith (09-15-2023)
  #143
Old 09-15-2023, 05:39 PM
RALLY RALLY is offline
Good call Wayne, she is a beauty, enjoy.
The Following User Says Thank You to RALLY For This Useful Post:
  #144
Old 09-15-2023, 09:09 PM
Arrowsmith's Avatar
Cool Rad Caps!
Here's something for everyone (I think !): I put my Nova together with a DeWitts aluminum rad. It's a beautiful sort-of-stock appearing piece. They also included a cool billet covered rad cap. But in my "stock appearing" mindset, I decided to swap the cap for a reproduction RC15. I never thought anything of it. But when I started driving the car a bit, I was plagued with what appeared to be runaway overheating. It was frustrating, but one day when it was hot, I put a towel over the rad cap to check to see if the coolant was disappearing. No hiss. No steam. Nothing. Further investigation revealed the reproduction cap wasn't seating on the rad neck. Obviously the cooling system wasn't holding any pressure. So I replaced the repro cap with the DeWitts' supplied cap. Bingo. I can park it outside on a 90-degree day, nosed up to the garage door, put it in park, let it idle and walk away without overheating. Instant cooling fix. I wonder how many other repro caps are like this?
The Following 4 Users Say Thank You to Arrowsmith For This Useful Post:
427.060 (09-16-2023), Dave Rifkin (09-16-2023), dykstra (09-16-2023), Xplantdad (09-15-2023)
  #145
Old 09-16-2023, 03:54 AM
427.060 427.060 is offline
I have a DeWitts aluminum radiator in my Beaumont. It didn't come with a DeWitts cap.
1968 Beaumont SD396
Old 09-16-2023, 04:00 AM
Arrowsmith's Avatar
Smile
Mine did but that's not the point.
Old 09-16-2023, 06:48 PM
jer jer is offline
I've got a couple repro caps, one on a dewitt's brass/copper and a couple others on oem recores.....no issues. Does your rad neck measure the same depth and seat diameter as oem? Spring pressure feel the same?
Old 09-16-2023, 08:23 PM
I understand that. My car runs hot when sitting in traffic. I'm wondering if the DeWitts cap will help like it did with your car.
1968 Beaumont SD396
The Following User Says Thank You to 427.060 For This Useful Post:
Arrowsmith (09-17-2023)
  #149
Old 09-17-2023, 01:02 AM
Arrowsmith's Avatar
Smile
Yes, but I believe the problem is in the cap. Over the years it seems other folks have had similar issues with repro caps. It’s kind of a hit and miss situation from what I decipher. I suspect if I had a rad cap pressure tester, I could nail it down exactly, but honestly since it’s working correctly now, I don’t think I want to spend $$$ on the test equipment😉
Old 09-17-2023, 01:13 AM
Arrowsmith's Avatar
Smile
The DeWiits cap is pricey, but I’d first check to see if your system is pressurized correctly (Be careful man…). I was pretty frustrated with mine in traffic until I resolved it. By the way, I can now watch the temp change as the thermostat opens. That wasn’t possible before. It would just keep climbing until the traffic cleared up (or I shut the thing off). I’m currently using a 180 Stewart Thermostat, but I’d like to try a 160 example (I have a similar drilled Stewart on order).
