Old 11-10-2023, 08:15 PM
Default Need fuel gauge help, very confused
I am pretty good with wiring but this one has me totally stumped. I always check every system on a car when I am done restoring to it, this one being a 70 Camaro.
Whenever I put in a new tank and sender I always check the sender before I install it in the tank and then again after its installed. This one tested perfect. 50 ohms at just over half a tank and 90 ohms with a full tank. This was all done manual with no fuel. Check
Install the tank in the car, the dash and all wiring. Turn key on, tank reads empty. Add 10 gals of fuel and gauge now reads just over half. Check
I then unplug the sending wire from the rear harness at the trunk. Gauge buries the needle to the past full mark. Check
Ground that same sending wire with a jumper wire and it stays buried to the right. Huh? Nothing I do can I get the gauge to read empty by grounding the sending wire.
The driver's side terminal of the gauge reads approx 12 volts and the passenger side reads 5 volts. Check. I also put a jumper wire from the ground terminal stud on the gauge to ground just in case I was not getting a good ground there (though the gauge would not have read correctly if it wasn't) but I knew it was.
Anyone have any idea what the heck is going on here? Yes the gauge reads fine when hooked up normally but I cannot get it to read empty when I ground the sending wire and for that reason I want to make sure I do not have another issue somewhere. Come on electrical gurus. Please help
Musclecar Restoration and Design, Inc
specializing in (only real) LS6 Chevelle restorations
Damien (11-10-2023)
Old 11-10-2023, 09:30 PM
67since67's Avatar
This is a head-scratcher for sure Rick, right off I don't have an answer. I'm guessing this car has a printed circuit dash cluster? I hate printed circuit clusters! I'd look very closely there. - Bill W
olredalert (11-11-2023)
Old 11-10-2023, 10:34 PM
Yes it does but I am getting normal readings on the back of the gauge so I don't think that is the issue.
Old 11-10-2023, 11:02 PM
Maybe a cold solder joint on the printed circuit board?
https://versae.com/avoiding-the-cold-solder-joint/
Old 11-11-2023, 12:00 AM
The odd part is the gauge seems to be functioning perfectly until I ground the sending wire at the trunk as it reads past full. Every other time on any other car it brings the gauge to completely empty.
Old 11-17-2023, 04:21 AM
enio45 enio45 is offline
find anything on this issue?
Eddie M
MBTMF
68 COPO Camaro 9737 non-converted YENKO
69 YENKO SC Camaro, Hugger Orange - born with engine!
Old 11-17-2023, 12:27 PM
Nope. Even called John at Red Line Gauge and he too was stumped. Never had this happen before and no explanation.
Old 11-17-2023, 09:41 PM
dustinm dustinm is online now
Rick you test/verified them the same way I did for 20 years.
So did you reinstall the wire to sender and the gauge worked again? Sent it?
Old 11-27-2023, 11:47 AM
dykstra's Avatar
dykstra dykstra is offline
Hi Rick, I know you retired, but did y’all ever get this figured out?
Dave Dykstra
2013 Corvette Grand Sport 60th Anniversary
NCRS#66003
“Education is what you get when you read the fine print. Experience is what you get if you don’t.”-Pete Seeger
Dykstra Motorsports
Old 11-27-2023, 01:39 PM
Nope. Gauge functions perfectly normal when attached to the sending wire, beyond full when disconnected and beyond full when grounded. I drained 1/4 of the fuel out and gauge read accordingly so since it works perfectly when connected I just have to live with it in my head.
The Following 2 Users Say Thank You to SS427 For This Useful Post:
dykstra (11-28-2023), RPOLS3 (11-27-2023)
