Register | Album Gallery | Thread Gallery | FAQ | Members List | Calendar | Become a Paid Member | Search | Today's Posts | Mark Forums Read |
Shops/parts to rebuild manual steering box and change ratio
Does anyone have a suggestion for a shop to rebuild a 5679142 Saginaw manual steering box and change the ratio? I have a dated box for my 69 Z28 but it's 6-1/2 turns LTL and I need it changed to the quick ratio 3-1/2 turns LTL. I reached out to Lee mfg and waiting to hear back from them. I was also wondering if there is a source for the internal parts to change it to quick ratio. I contacted Borgeson but they only sell new units.
69 Z28 JL8, #'s match - being restored |
The production 1969 Camaro manual steering gear [4.8 t L-L] was the same regardless of application. To achieve the faster Z/28 ratio, a longer pitman arm [5.75"] and shorter steering arms were used.
N44 on a Z/28 did use a gear with a different ratio; 2.9 t L-L. Absolutely miserable for daily driving.
Learning more and more about less and less... |
Call Lare's and ask about this. I have a quick ratio gear set in a vintage '66 Chevelle box, but it's power. Don't know if they change manual ratios.
https://www.larescorp.com/
Mitch 1970 Chevelle SS 1966 Chevelle SS 1967 Camaro ss/rs 1938 Business coupe, street rod 2000 FXSTS, original owner, 13k miles |
I had these guys rebuild mine. http://www.powersteering.com/ I sent my manual box to them and they did an excellent job.
And bought a pitman arm shaft from the guys. https://www.midweststeering.com/ They might have what you are looking for. |
I got around 6-1/4 to 6-1/2 turns L-L with the box out of the car, is the Camaro box around 5 turns L-L out of the car or in the car?
The info came from Chevy service lit.
#1. The standard [exc Z/28] manual steering ratio was 24.8:1 [gear] 28.3:1 [overall]. 4.8 turns L-L. #2. The standard Z/28 manual steering ratio was 24.8:1 [gear] 21.4:1 [overall]. 3.5 turns L-L. I believe A bodies were front steer; steering gear does not interchange.
Learning more and more about less and less... Last edited by William; 09-07-2022 at 06:11 PM. |
Thread Tools | |
Display Modes | |
