Old 03-18-2024, 04:03 AM
Default NOS AC A329C Air Filter w/ Square Wire Mesh
Vintage NOS AC A329C air filter with square wire mesh outer wrap. Never installed on a vehicle. Complete with 'patina-ed' original box that has normal shelf wear and some minor staining. Paper element and wire mesh have minor discoloration as you would expect in a 50 year old item. Photos tell the whole story here. Filter will be shipped inside its original box, which will then be inside another box with plenty of protective padding around it. Selling at no reserve with a $9.99 minimum opening bid.
https://www.ebay.com/itm/266722204644
Bill Pritchard
The Following 4 Users Say Thank You to Bill Pritchard For This Useful Post:
69M22Z (03-18-2024), McCune (03-18-2024), napa68 (03-18-2024), ragtop (03-18-2024)
Attachments - The Supercar Registry Used-1973-Chevrolet-Corvette-L82-4-Speed-11k-Miles-1709840441.jpg IMG_5626.jpg IMG_5625.jpg IMG_5624.jpg
Old 03-18-2024, 12:42 PM
bergy's Avatar
bergy bergy is offline
Hi Bill - WOW - nice filter! Can one of the judges confirm what years this square mesh is technically correct for? I don't believe that it's first gen Camaro - is it?
Old 03-18-2024, 09:16 PM
I believe it's correct for the QJet cars with closed element air cleaner such as a 300hp 350 and a 325hp 396, and undoubtedly a number of others. I bought this years ago for my black 69 Chevelle SS396 convertible and never used it.
Bill Pritchard
Old 03-18-2024, 09:38 PM
napa68 napa68 is online now
Here is a pic of what I believe to be an original assembly line element. This is in an 11k mile 73 Corvette that I have currently.
The Following 3 Users Say Thank You to napa68 For This Useful Post:
60sStuff (03-19-2024), 67since67 (03-19-2024), dykstra (03-19-2024)
Old 03-18-2024, 10:56 PM
jeffschevelle jeffschevelle is offline
The white BEST WAY TO PROTECT YOUR ENGINE ink stamp was used from approximately March 1968 through at least November of 1974 based on original filter and NOS air cleaner assembly box dates.
The earliest PROTECT YOUR ENGINE (without BEST WAY TO at the beginning) filter I have documented was in a box with 1975 date (no month or day).
So if the ink stamp just says PROTECT YOUR ENGINE (without BEST WAY TO), then the filter was made no earlier than December of 1974, at the earliest.
Note that there are filters being sold on ebay where it is obvious that the BEST WAY TO has been added with a separate stamp, to make a later filter look like an earlier one ...
As to the mesh, the horizontal / vertical version of the soldered wire "square mesh" was the second version of that wire used. The first version was the exact same soldered wire with square-holes, but it was cut so that the wires were oriented diagonally on the completed filter. It was in use at least as early as 1960.
I have not pinned down the exact changeover date from diagonal "square mesh" to horizontal/vertical "square mesh", but the latest dated box with a diagonal mesh I have documented is 7/14/1969, and the earliest horizontal/vertical mesh I have documented was in a box with 1970 date (no month or day). And obviously both of those were BEST WAY TO filters since made before 11/1974.
Happy hunting!
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
The Following 10 Users Say Thank You to jeffschevelle For This Useful Post:
60sStuff (03-19-2024), 67since67 (03-19-2024), Bill Pritchard (03-19-2024), DAVE H (03-19-2024), L78_Nova (03-19-2024), napa68 (03-18-2024), ruralrte66 (03-19-2024), Steve Shauger (03-19-2024), Tidmack (03-20-2024), YenkoYS-199Stinger (03-19-2024)
Old 03-19-2024, 12:58 AM
60sStuff's Avatar
60sStuff 60sStuff is offline
Default AC air filter Mesh
In the mid 60’s (64,65,66) the Pontiac GTO with the 3x2 would have a foam filter supported by a round bronze screen. This was a reusable filter.
The next filter from that era were the wire mesh and they were a one time use.
Two types of mesh are shown below.
The first design was a diagonal heavy solder mesh. Impossible to find.
The second design was a stamped mesh.
Both these filters have their dates inked on the box end.
I’ve misplaced my old notes, but the early boxes only have AC.
The later boxes have AC plus GM. I think this change started in the late 60’s, early 70’s.
Old 03-19-2024, 01:35 AM
luzl78 luzl78 is offline
Look at the knowledge on this site.
The Following 3 Users Say Thank You to luzl78 For This Useful Post:
Bill Pritchard (03-19-2024), napa68 (03-19-2024), Tidmack (03-20-2024)
Old 03-19-2024, 06:26 AM
BJCHEV396's Avatar
It's amazing!
The Following User Says Thank You to BJCHEV396 For This Useful Post:
Big Block Bill (03-19-2024)
