Register | Album Gallery | Thread Gallery | FAQ | Members List | Calendar | Become a Paid Member | Search | Today's Posts | Mark Forums Read |
Correct part number for 67 BB motor mounts?
Having trouble finding the correct 67 BB Camaro motor mount part number. I have #701s, but that may not be correct?
Thanks |
Not sure if that's what you're looking for, these are the frame mounts..
Thanks Chuck. I have the original frame mounts. Wanted the motor Side mounts #. I found a set.
You found a set?,can you relay the part#'s?
I haven’t received them yet. Non-locking early take offs. I believe 3886466
3886466 is the part number shown for 67 Camaro 396 in the July 1967 parts book revision. Those are the ones without an affixed nut on either side.
The 67 Camaro AIM does not show mounts in L35/L78 sections, which means they should install same as the 283 small block V8 mounts as shown in Section 6. Section 6 shows mounts without any affixed nuts and shows a loose washer and nut being used. So 3886466 is most likely assembly line correct. Trivia - 65-67 Chevelle 396 assembly line mounts were the exact same design mount except with an affixed nut on the rear facing side, so they are left-right specific. (It is all but impossible to find a good set of those.) The 67 Chevelle part numbers were 3886467 and 3886468. But the initial service replacement part was 3886466 for both sides (supply your own nut, I guess).
Jeff Helms 65 Z16 Survivor 65 Z16 drag car 66 Chevelle L78 unrestored 67 Chevelle L78 unrestored 67 Camaro SS350 Survivor |
The Following 5 Users Say Thank You to jeffschevelle For This Useful Post: | ||
67since67 (08-26-2022), bergy (08-26-2022), Chuck_Burg (08-27-2022), Steve Shauger (08-26-2022), X66 714 (08-26-2022) |
Thread Tools | |
Display Modes | |
